Home > General > 2 questions???
JohnP007
United States 2008 Range Rover Sport 4.4 V8 HSE Buckingham Blue
2 questions???
First is there a reason why my compass doesn't work on 4X4 mode? When I select it, it says something like it isn't available.... Second is there anyway to set the truck up to automaticly lower itself when you shut it off then go back to reg. when you start to drive or do you always just have to push the button yourself?
Post #234780 Thu Aug 27 2009 11:17am
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
First of all: It is not a truck! Have a look what Andy drives in the off-topic section, that's a truck! Rolling Eyes Wink
I can't answer your first question, however I can answer the second: It is not possible to automatic lower the RRS, but if it is just down and not locked it will raise itself automatically if you just start driving: Once you exceed a certain speed (I think something about 6mph) it will raise itself to normal height. RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #234781 Thu Aug 27 2009 11:26am
yanks call SUVs = trucks Shocked Shocked Smile
as for the first question where is Bobby the *tech brain*? when you need him Smile
i will pm him Smile
Post #234783 Thu Aug 27 2009 11:37am
JohnP007
Well coming out of a BMW 745 the range rover is a truck Smile
I know it adjusts it self up when going over what ever speed. I guess I could set my 3rd button on key to have it lower insted of popping open my boot, I just thought it would be cool if it lowered on it's own.
for my other question I just feel it to be odd that it doesn't work, it just shows me the 4 wheel mode. Does everyone else's work when you select it?
Post #234785 Thu Aug 27 2009 11:41am
The compass thing is normal. 2005 Zambezi TDV6 - Gone but not forgotten
Post #234786 Thu Aug 27 2009 11:46am
JohnP007
Thank You.... so does it EVER work?
Post #234787 Thu Aug 27 2009 11:47am
Yes but I can't remember how. 2005 Zambezi TDV6 - Gone but not forgotten
Post #234788 Thu Aug 27 2009 11:49am
flydive
But for that to work you have to have the hazard lights on. '08 RRS TDV8
Post #234800 Thu Aug 27 2009 12:13pm
JohnP007
[quote="flydive"]
But for that to work you have to have the hazard lights on.[/quote
U do? Sad]
Post #234801 Thu Aug 27 2009 12:15pm
Bobby
i will pm him Smile
Got your PM, Angel! Laughing
I'm not too sure of this compass thing myself. We too get a similar message and the general feeling is that it's because we do not have the proper Navigation CD installed. It need the CD to navigate.
According to the literature..
4x4 I
4x4i gives the driver additional information regarding the following vehicle systems:
Suspension travel
Gear selected
Range selected
Terrain response
Vehicle heading
Compass heading
Steering wheel angle.
The 4x4i System uses inputs from other vehicle systems to display information about suspension and transmission operation along with navigational information.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #234811 Thu Aug 27 2009 1:07pm
JohnP007
I have the factory CD that came w/the car... That's weird... OK..
Last question for the day Smile
I'm confused w/the "Prog" button and defrost what is the diff? Reading the book seems that the Prog button puts on both front and rear defrost, NO? So would it be used if I wanted/needed both front & rear defrost on and if I needed only front OR rear defrost I would hit the the front OR rear button on it's own? Or is there a different use? Like for just frost/fog and defrost is for melting ice/snow? Sorry I just don't understand the book.
Post #234815 Thu Aug 27 2009 1:21pm
diamond
Greece 2009 Range Rover Sport TDV6 SE Alaska White
yes it works:
go to off-road navigation and check if compass is there and working (it should) then go back to your 4x4 information screen and click the compass symbol
voila!!!
I don't know why it has to be like that Shocked 2009 Range Rover Sport 2.7 TDV6 SE, Alaska White, Almond leather, tinted windows, active rear diff, tow pack, HiICE, full spare: gone and already missed
2004 Fiat Panda 1.2 Climbing 4x4
http://www.youtube.com/watch?v=fAg4DdXAp7Y
Post #234819 Thu Aug 27 2009 1:28pm
flydive
[quote="JohnP007"]
U do? Sad]
Yes, unfortunately Sad '08 RRS TDV8
Post #234821 Thu Aug 27 2009 1:34pm
Who says the internet doesn't work properly ? Smile
Post #234824 Thu Aug 27 2009 1:43pm
Alias
Switzerland 2006 Range Rover Sport TDV6 HSE Java Black
I know the problem with the compass. I had the same problem.
You have to calibrate the compass. I'm not sure how but check under setting on your navigation.
Post #234826 Thu Aug 27 2009 2:02pm
