Home > My Range Rover Sport > Biggles - 2.7 TDV6
Biggles
Biggles - 2.7 TDV6
Just info about my car,
Its a 2005 Range Rover Sport 2.7 TDV6 HSE. Java Black.
Factory Options Fitted
Personal Telephone Integration,
Privacy Glass,
Tow Pack,
Harmon Kardon Logic 7 Stereo,
Sunroof.
So far over the moon with the car and will keep every body up to date with its progress and will post some photos soon. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #1109 Fri Jul 22 2005 12:09pm
Biggles
Additions To Car
Have bought,
Full set factory floor matts,
Rear load space mat,
Sill protection tread plates.
All items original Land Rover equipment. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #1110 Fri Jul 22 2005 1:35pm
nickp
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi Biggles
Are you seeing any Suspension warnings messages in the display ? try going from access height to off road height. Could you let me know if you get "Suspension raising slowly" or other messages. Have had mine now for 3 weeks and have been getting these messages on and off.
Post #1113 Fri Jul 22 2005 5:08pm
Biggles
Not seen any of these suspension messages, but have seen today the red handbrake light staying on after removing the ignition key for about twenty seconds.
Have also seen once something to do with low power on the stereo screen but I have been told this is a power save for the car when the radio is on and the engine is not running. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #1114 Fri Jul 22 2005 5:40pm
nickp
I also get the handbrake light which seems to be normal and the low power mode is designed so the volume wont go so high I think when the car is not running. If you get a chance play around with the suspension from access to off road a couple of times and see if you get the warnings.
Post #1115 Fri Jul 22 2005 5:43pm
Biggles
Nick,
Had a chance to play with the suspension last night while sat outside maccy d's.
Up and down from access to off road over and over and no problems. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #1126 Sat Jul 23 2005 8:37am
nickp
Biggles
Hi thanks for the update . Mine was the same for the first few weeks then I had some warnings. Just had a new compressor fitted , still got the same problem. It sems to be an on-going problem. Am going to test over the next week.
Post #1127 Sat Jul 23 2005 9:01am
NeilR
Hi
I had some of these issues with my Discovery 3 and most of them were cause by water ingress in the connectors or wiring looms. did you start getting the problems after giving it a good presure wash or heavy rain ?????I had 3 ride height sensors replaced.
Neil 2010 RRS TDV8 Overfinch GTS
Post #1128 Sat Jul 23 2005 9:08am
nickp
Hi NeilR
My dealer seems confused as to whether I have a fault. Suspension raising slowly appears in the dash display but this does not happen every time i raise the suspension. There is no chime and you may miss the display if you are not looking for it . I have not jet washed and we have had no rain until yesterday. But on this forum I seem to be the only one reporting these warnings ?? on the RRS .
Post #1186 Mon Jul 25 2005 2:44pm
grommet
United States
"Suspension raising slowly" is not a fault exactly. It just means the air tank doesn't have enough saved and the air compressor is used to assist. Many people don't even notice... (same on Disco 3/LR3)
Post #1192 Mon Jul 25 2005 5:24pm
Biggles
New Accessories Fitted,
Mud Flaps, Front and Rear.
Side Steps,
All went on very easily apart from the little nasty plastic fateners manufacturers use to hold trim in place.
Pics are coming soon.
Post #1303 Sat Jul 30 2005 1:38pm
Biggles
My first pic posted ( she has just been washed after a week getting dirty)
Post #1319 Mon Aug 01 2005 12:23am
BN
Biggles, take a look at the string I started http://www.disco3.co.uk/forum/viewtopic.php?t=798
on the D3 site. I am convinced that most of the electronic faults are as a result of firing the car up too quickly after switching on the the ignition. Both the dealer and myself plus the guys as you can see in the thread have tried it with similar results. Gurvans wife had a cruise control fault and followed the idea and found it did not repeat.
Post #1327 Mon Aug 01 2005 8:16am
Biggles
Have just added the supercharged grille side vents and also the front and rear black Landrover badges.
Impressed with how much the grille brings out in the car. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #2330 Thu Sep 15 2005 10:43am
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
BIggles, how easy are the mud flaps to fit? They look simple from the instructons online, is that the case? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #2336 Thu Sep 15 2005 2:47pm
