![]() | Home > General > What to look out for on a test drive |
| BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942
Hi Cavham
Yes, got that bit...Welcome to our gang.
Yes, I think I have got that bit too ......but it depends if your RRS has Dynamic Stability as to whether or not it knocks.
Sorry, what are you talking about here?
Someone is buying you some replica wheels as a present? How nice. I have never had a bad experience with any presents and if I do, I re gift them. Gone - 2008 Stornoway Grey RRS 2.7 TDV6 Gone - 2009 Buckingham Blue RRS 2.7 TDV6 Gone - 2010 Alaska White RRS 5.0 V8 Aspirated Gone - 2017 Chawton White RRS 5.0 V8 Supercharged Current - 2010 Java Black RRS 5.0 V8 Aspirated Current- 2024 RRS P400 SE Dynamic |
You don't say with engine and spec level your 2006 car is - not all TDv6's had the optional suspension set-up in 2006 so it's possible your car doesn't have it. Also PTI was only standard on Supercharged back then, it was optional on all the others IIRC so again your car may not have the handsfree. If you can get hold of the VIN (in a clear section of the windscreen surround bottom left corner of the screen you can take it to a franchised Land Rover dealer and ask them to run a history check - this will show up also any TSB's carried out on the car and the should tell you the full spec as well as any dealer fitted LR approved accessories fitted to it.
| Cavham Member Since: 30 Jul 2009 Location: Berkshire Posts: 91
Would help to give more. It is a TDV6 HSE 2006/56 plate for a 2007 model.
