Home > Maintenance & Modifications > DOOR PANEL SUPERCHARGED DECALS- How do I fit them?
kedz
United Kingdom 2009 Range Rover Sport TDV6 HSE Alaska White
should the door card badge's be the same size as the one on the steering wheel?
Post #226910 Thu May 28 2009 11:56am
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
Thanks to all for how to replace emblems which I just did in about a hour. The SC door emblem will fit perfectly on steering wheel. I did drill small hole in center of existing tin badge ,then pulled with pliers. But then I used an exacto knife and very carefully trimmed down rubber. Then cut off tabs by using razor knife over flame. I then sanded back of badge very lightly and epoxyed in. Perfect! mike murphy
Post #228804 Tue Jun 23 2009 4:06am
Tim in Scotland
Could there be an airbag/ safety reason why the steering wheel one has prongs on it and isn't stuck on like the others...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #228818 Tue Jun 23 2009 9:36am
funnyguy1
Hi Tim, I don't think its an air bag saftey issue. I went very slowly as I could see where you could go thru the
rubber horn pad material. I just went deep enough so the badge would fit in tightly as the green one. Was not sure why RR designed the door badge the way they did with the cup and phillips screw. Could have just snapped in with the prong on each end. Came out great though! mike murphy
Post #228860 Tue Jun 23 2009 2:32pm
funnyguy1
Being the consumate fanatic, if anyone is changing from the HSE badges to the SC here is another tip. If you are changing the front/rear emblems and the door emblems you may also want to change the badge on the horn pad
The emblem on the SC wheel cap is identical to the SC horn badge(metal) except without the 4 prongs. Use a hairdryer on the wheel cap badge and it prys right off, then follow previous tips on removing horn badge and epoxy the SC badge in place. mike murphy
Post #231275 Mon Jul 20 2009 1:09am
