Home > Maintenance & Modifications > Lubricant report
Snoozer
Denmark 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Lubricant report
It´s problarly in here allready somewhere, but.....
I recently posted about guidence in regard of changing oils and lubricants. I did some research and found a Castrol dealer nearby, I went to visit him and besides a few old British racing cars, like Lotus S7, MG´s and a Interceptor, he had a SC in the garage, so I think he knows what he is doing.
He had a Lubricant report for the TDV6, and he modified it with he´s recommendations for me.
Lubricant Report
Land Rover, Range Rover Sport LS, Range Rover Sport 2.7 TdV6, 2005-
Manufacturer: Land Rover Ltd. Solihull - West Midlands, United Kingdom
Drive type: a.w.d.
Cylinder capacity: 2720 cc
Power output: 190 HP / 140 kW at 4000 RPM
Engine TDV6
Diesel; 4-stroke, 6 cylinder, V, 4 valves/cyl, Turbo lntercooler, liquid coaled
Power output: 190 HP/140 kW at 4000 RPM
Capacity 5,54 Liter
Use: Normal
Change 24000 km or 12 months
OEM recommendation
year-round:
Ford M2C913-B SAE 5W-30
Recommended: Castrol Magnatec 5/30 A1
Purchased: Edge Sport 0W/40
This oil is a bit more stable in regard to consistency, it operates within a smaller area in regard of temperature/thickness
Transmission, automatic ZF 6HP 26
Automatic
Capacity 9,5 liter
Gears forward: 6
Gears reverse: 1
Use: Narmal
Change 240000 km or 120 months
OEM recommendation
year-round:
ATF, M-7375.4
Recommended: Castrol Transmax Z
Transferbox
Capacity 1,5 Liter
Use: Normal
Change 120000 km or 160 Months
OEM recommendation
year-round:
Special gear oil Shell TF 0753
Recommended: Original - Shell TF 0753
Differential front
Capacity 0,61 liter
Use: Normal
Check 48000 km/24 months
OEM recommendation
year-round:
API: GL-5 SAE 75W-90
OEM recommends: Castro/ SAF-XO
Recommended: SAF-XO 75/90
Differential, rear
Capacity 1,1 liter
Use: Normal
Check 48000 km or 24 months
Change 240000 km/120 months
OEM recommendation
year-round:
Recommended: SAF-XO 75w/90
Differential, rear + ETM
Capacity 1,5 1iter
Use: Normal i I
Check 48000 km or l24 months
OEM recommendation
year-round:
Castrol SAF Carbon M.O.D.
Recommended: Castrol SAF-X3 75w/90
Active Stabilization System
Capacity 2,4 liter
Use: Normal
OEM recommendation
year-round:
ZF-09B-
Recommended: Original - ZF-09B-
Hydraulic brake system
Use: Normal
Change 36 months
OEM recommendation
year-round:
Brake fluid, DOT 4
Recommended: Castrol Super Response DOT4
Purchased: Castrol Super Response DOT4
Power steering
Use: Normal
OEM recommendation
year-round
ZF-09X-
Recommended: Original ZF-09X-
Cooling system
Capacity 9,4 liter
+ additional heater: 10,35 liter
Use: Normal
Water with antifreeze (OAT), 50%
OEM recommends: Havoline XLC
Recommended: Castrol SF
Purchased: Castrol SF
IMPORTANT!!!!!! You have to mix the SF Antifreeze with 50% water, USE ONLY Demineralised water, the calcium in the water that comes from the tap, will f....k up your engine, especially since it´s an aluminium engine.
If sulphercontent in the used dieseloil is more than 0,7%, motoroil change must not exceed 6.000 km.
If sulphercontent in the used dieseloil is between 0.3%-0.7%, motoroil change must be halved with a
maximum of 12.000 km.
_______________________________________________________
I allso bought a Brake Bleeder working with the compressor, not only is it a smart way of changing the Brake fluid, it is allso a lot better for all the brake components, to suck the fluid out, instead of squizing it out using the brakepedal...I was told... Rolling Eyes
I did see the post in regard of changing filters, which I will do to, but still, any advice/tip/trick is more then welcome..
Cool RRSport 2005 TDV6 2.7 HSE - Named "The Majesty" - Bought 1/7-2009.
Post #230633 Mon Jul 13 2009 11:04pm
Tim in Scotland
Recommended engine oil is 5W30 and LR uses Magnatec - I would imagine that if you used 0W40 and had a claim for engine problems in the warranty period LR would throw it out because you haven't used the makers recommended lubricant 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #230639 Mon Jul 13 2009 11:32pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Crikey that's deep Shocked Shocked L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #230641 Tue Jul 14 2009 12:43am
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
Hate to say this, but the guy giving you guidance is a complete idiot. No way would you let your transfer case, transmission or front/rear differentials run for that long in mileage/kilometers or time - completely off base for preventative maintenance. PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #230643 Tue Jul 14 2009 3:33am
Snoozer
I am out of warranty, and have to take matter into my own hands in regard to maintaining my RRS the best way. I did a lot of checking up on 0W/40 and i did change to that. Changed Oil filter, brake fluid, Air filter aswell. and I am about to change the Fuel filter and the Coolant fluid/sensor......Cant find the best spot to emptying the coolant fluid though...any advice? Cant find the location on the "Pollen filter" either?......cant find my RRS, anyone seen a Buckinham blue RRS??
@PJPRO1: 2 companies, both located in britain, has a corebusiness based on retrieving specifications for lubricants from car manufactorers worldwide. The basic Lubricant report came from one of those companies, with a reference to Land Rover UK as the provider.......BTW, it would be a lot more constructive to pass on your knowledge on how to do things instead of just calling other people, thats trying to help out, idiots....thats a bit to easy imo Wink RRSport 2005 TDV6 2.7 HSE - Named "The Majesty" - Bought 1/7-2009.
Post #230961 Thu Jul 16 2009 12:56pm
PJPR01
I do believe in preventative maintenance as well...so the guidelines you have been given by this chap are far from what I would consider preventative, but are actually bordering on neglect of your vehicle.
From my own experience with the RRS, I changed the transfer case fluid at 57K miles, the front and rear diffs and transmission fluids at 70K, and I can tell you that the diffs need changing much more often than this, particularly if you are doing any sort of off roading.
The front diff fluid was black
The rear diff fluid was mocha brown, not clear
The transmission was still clear and had more life to go...
Having said that...no way I would wait 240K or approx 145K miles or 10 years to change any of these items...that's way overboard.
As far as preventative maintenance goes...this makes much more sense to do earlier...for the price of the fluids.
Good luck! PJPR
Cairns Blue HSE
Post #231021 Thu Jul 16 2009 7:31pm
Snoozer
Thats cool, very constructive and very usefull info. Especially since i bought my RRS from a lady which have done a minimum to maintain it, and it has by now done 80.000 miles.....
I dont do off road yet and the car have not done any OR so far, but I do intend to, so I will follow your guidence as to what is needed and when.
"As far as preventative maintenance goes...this makes much more sense to do earlier...for the price of the fluids. ".....Wise words...
Thanks a lot m8 Thumbs Up RRSport 2005 TDV6 2.7 HSE - Named "The Majesty" - Bought 1/7-2009.
Post #231058 Fri Jul 17 2009 10:27am
Bobby
Pollen Filter Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #231059 Fri Jul 17 2009 10:38am
Snoozer
Dunno how to thank you, for all your help - Cheers m8 Very Happy Bow down Bow down Bow down Bow down RRSport 2005 TDV6 2.7 HSE - Named "The Majesty" - Bought 1/7-2009.
Post #231078 Fri Jul 17 2009 3:52pm
