Home > General > Headlight assembly removal
kennybahr
2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Im a newbie, just got an 06 RRS. I noticed this morning that the passenger side headlight amber bulb is out. I went to the auto parts store and picked up a new bulb. However, I cannot figure out how to get the headlight lens off. All I need to do is replace the amber bulb. Please help
Thanks,
Kenny
Post #230466 Sun Jul 12 2009 9:37pm
wullie
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi
Easy peesy, lift bonnet/hood to yourself there is two metal slide plates one left one on right side of head lamp, just slide them up about an inch, pull the full head lamp cluster out then you will see the plug connector press and pull to remove, fit new bulb then reverse to refit.
cheers wullie Very Happy
Post #230469 Sun Jul 12 2009 10:25pm
kennybahr
wullie wrote:
Hi
Awesome, thank you so much. Its done, took all but a couple of minutes.
Kenny Very Happy
Post #230470 Sun Jul 12 2009 11:12pm
wullie
Your welcome thats what this forums for
cheers
Wullie
Post #230595 Mon Jul 13 2009 5:34pm
Tim in Scotland
Take care that the key is not in the ignition before you touch the headlights. When I had my LED's in my headlamps fitted the fitter wanted my key in his poccession as he had received a nasty shock when changing the HID Xenon fittings on another car, with the key in the ignition - apparrently the lamps start to build up charge (many many volts) as soon as the key is put in the ignition........................... I don't know how true this is but it seems like a sensible precaution to me 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #230597 Mon Jul 13 2009 6:09pm
wullie
Yeh Tim this is possible, would blow a pacemaker and make your hair stand out' nasty, your right keep your keys in yer pocket. well spotted.
cheers
Wullie Smile
Post #230624 Mon Jul 13 2009 9:47pm
