Home > Technical > squealing at front
exige1
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
squealing at front
Seem to have a problem with the front end squealing when i move the steering wheel left to right.
sounds like a metal squeal. This happened after a motorway journey of about an hour.
Any ideas? Crying or Very sad
Post #214661 Tue Mar 03 2009 11:52am
Does it sound like a "wear" noise.... could be front suspension bushes. Time for a trip to the dealer Smile
Post #214680 Tue Mar 03 2009 12:12pm
exige1
Great just out of warranty.
Thanks
Post #214691 Tue Mar 03 2009 12:52pm
LR usually cover just out of warranty repairs - one word of warning though, whereas before they would do various repairs within say 6 months they now only will do one, so get your dealer to give you the option to pay if it's a cheap job just in case a bigger problem is around the corner, the choice is yours. 2005 Zambezi TDV6 - Gone but not forgotten
Post #214694 Tue Mar 03 2009 1:02pm
Sexy Pauly
i have this same noise, coming from the steering rack inside the car, dont know if it is superficial plastic rubbing, or if its a mechanical problem!
aparently i need new antirole bars... would that affect it? RR Sport supercharged 06
strut grills, strut 22" wheels, Full Kahn Kit
Brembo big brake kit, tinted front and rear lights
CLS 63 AMG Mercedes 2008, Cayenne Turbo S 2007, C32 AMG mercedes 2004, Vito Van 111CDI 2004
Post #214765 Tue Mar 03 2009 4:19pm
Bobby
There have been quite a number of TSBs on steering squeaks etc.
Here's one...
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #214900 Wed Mar 04 2009 8:02am
exige1
The noise is actually coming from the front brakes. Pads and disks are in good nick tho. Going to give them a good clean up and see if it stops. It stops squealing when brakes are applied and gets worse on right hand bends. Confused
Post #215610 Fri Mar 06 2009 4:09pm
james5599
exactly the same problem matey,
happened on my ffrr and i had the discs and pads replaced all around it cured the problem,
i ve had the discs and pads done on my rrs and its still doing it......
i ve found out it seems to do it more when the brakes are hot.....and when i first set off it doesnt do it....
did you find a fix?
cheers
james
Post #229694 Sun Jul 05 2009 3:23pm
Josh
Just had a Tsb done to my car to remove a small squeak from the power steering. Washed out and an additive added cured the problem.
Before you ask I don't know the tsb number Embarassed TDV6 - gone
TDV8 - gone
Post #229698 Sun Jul 05 2009 5:41pm
james5599
THE NOISE COMES FROM THE WHEEL and not steering wheel!
jeez!
j.
Post #229700 Sun Jul 05 2009 6:09pm
Bobby
it could be the same as the above... Malaysia Boleh!
Post #229719 Sun Jul 05 2009 11:51pm
james5599
Rightio,
Seems the noise was actually coming from the rear wheel, one the techies drove around the carpark with half the garage following him around! checking for the noise....
It seems when the pads get low, the caliper doesnt have the movement to pull the pad completely off of the disc,
and so it sits on the disc and produces the god awful noise!
New pads in the rear yesterday and so far so good!
cheers
james.
Post #230650 Tue Jul 14 2009 8:03am
