Home > General > Front windscreen trim
Big D
Scotland 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Afternoon all, has this happened to anyone? driving along the motorway and an almighty banging starts coming from the roof?? pulls over, gets out and the trim along the top of the windscreen is only just holding on at one side (and was flapping about when driving, hence the noise) slid it back on and drove home slowly!! So, dealers are now closed today, so my question, a bit of silicone along the trim a stick it back in semi-permanent, or be fleeced by the dealer on Monday for (I imagine) similar job? thoughts?
Post #229643 Sat Jul 04 2009 12:30pm
ELD70
Very common if a windscreen has been replaced but no new clips fitted to the trim when refitted. Go to a dealer for a few clips to secure it permanently, not expensive.
Post #229644 Sat Jul 04 2009 12:33pm
Big D
Wow, quick and spot on answer! Thanks ELD70 Bow down
Post #229645 Sat Jul 04 2009 12:39pm
Tim in Scotland
Or a trip to the folks that replaced the screen and ask them to now re-do the job properly! Unless of course the dealership replaced the screen in which case you are heading there for a visit on Monday morning. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #229646 Sat Jul 04 2009 12:43pm
Big D
Only had the car since Jan, and no recent windscreen replacement that I know of? thanks for advice anyways Tim
Post #229648 Sat Jul 04 2009 12:59pm
TheDB
This happened on my RRS TDV8 MY08 last month shortly after purchase. Driving along and suddenly started to hear banging on roof. Turns out that the top trim of the windscreen has detached about 75% across the top of the windscreen.
Back to main dealer under warranty. They had to remove the windscreen to replace offending trim strip and fix.
Post #229696 Sun Jul 05 2009 5:23pm
Big D
trip to the dealers, new windscreen trim with adhesive tape £6. rip the backing of the tape, slip it on, job done! phew Thumbs Up
Post #230117 Wed Jul 08 2009 10:20pm
t72bogie
United Kingdom 2013 Range Rover Sport Supercharged HST Firenze Red
Just resurrecting an old thread, my windscreen trim finally came off today, has been flapping about for a few weeks and been putting it back in
I was at the dealers having a service but they told me the only fix is to have a new windscreen ? I cant just buy the trim and stick it back in myself
Has anyone got any recent experience of this ?
...maybe I just need to aquire some windscreen chips ! cheers
bogie
2020 RRS 3.0 HST
2008 RRS 4.2V8 HST
Post #460713 Tue Apr 28 2015 8:00pm
Richturbo
United Kingdom 2013 Range Rover Sport Supercharged Izmir Blue
You can by a new trim, apply a bead of sealant/adhesive & slide it onto the top of the windscreen without having to remove the glass. The adhesive windscreen fitters use is best for it & im sure a windscreen fitter would do it for a small fee! Range Rover Sport Autobiography Dynamic 5.0 Supercharged
Range Rover Sport 4.2 Supercharged First Edition
Post #460717 Tue Apr 28 2015 8:22pm
t72bogie
thanks, will give it a try. cheers
bogie
2020 RRS 3.0 HST
2008 RRS 4.2V8 HST
Post #460719 Tue Apr 28 2015 9:43pm
lazysteve
Bulgaria 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi, had this on mine, twice. I found the culprit in the end.
Lazy car washers. They tried to remove dead flies and other stuff with the pressure wash lance.
Get right up close and the water jet breaks the seal, after a while it flips off at high speed.
Hope that helps.
Used two part epoxy to stick it back.
Cheers.
Post #460780 Wed Apr 29 2015 6:47pm
t72bogie
mmm...starting to sound familiar with the local hand car wash guys, might have got a bit keen with the jet wash
anyway, ive tried to put it back in with some tiger seal windscreen sealant stuff, will see how it goes....and keep an eye on the car wash guys next time cheers
bogie
2020 RRS 3.0 HST
2008 RRS 4.2V8 HST
Post #460999 Sat May 02 2015 4:44pm
