Home > Technical > NEW RRS TDV8 couple of minor questions please
e6ext
England 2007 Range Rover Sport TDV8 HSE Java Black
Hi all,
just collected an 07 TDV8.. its brilliant, thanks To Kam who i picked up details from here ( highly recommended)
A couple of bits i am trying to work out? Shocked
1) the first is i am missing the owners manual ( hence the next questions) wheres the best place to get one. Confused
2) how do i get the split tailgate to work. i try the handle above the number plate and nothing happens? is this s a common issue or am i doing it wrong? Embarassed
3) i cant seem to get the memory seats to work all aaadjustments seem to be working fine just cant seem to get stored? again tips please? Embarassed
thanks guys hope you can help me out
Rob
Post #229283 Mon Jun 29 2009 2:34pm
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
try www.ownerinfo.landrover.com for the time being. Thumbs Up MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #229284 Mon Jun 29 2009 2:53pm
Welcome
1. If the car came through Kam there might be a suppying dealer - speak to Kam.
2. You are doing the right thing I think - are you pressing on the rubbery button, if so there's a problem if it doesn't open so get it fixed at any LR dealer, it's a warranty job.
3. Adjust your seat to required position then press button 1,2 or 3 at the same time as the mem button. 2005 Zambezi TDV6 - Gone but not forgotten
Post #229285 Mon Jun 29 2009 2:59pm
KiwiRRS
New Zealand
Locked Doors?
Could be that you have your doors locked (except the drivers door) as this will prevent the tail gate opening. Unlock all doors by the remote or push the little lock/unlock button above the radio. If this doesn't work then there may be a fault.
Post #229343 Tue Jun 30 2009 9:23am
Josh
You have to press the unlock button twice on the fob or the unlock button on the dash. Once all doors are unlocked just lift the lid.
Do not make the mistake of pushing that black button as well as lifting the top section at the same time as you will cause a problem. And if you decide you need it all open then close the top lid first.
If that doesn't work then I'm stumped. TDV6 - gone
TDV8 - gone
Post #229403 Tue Jun 30 2009 9:09pm
