![]() | Home > Technical > Starting problems TD8 |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554
Sounds like the ignition barrel - what you put the key into. Are there any fault codes? |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
Back to the dealer and unleash hell:
| mexi Member Since: 28 May 2009 Location: Rome Posts: 16
Good morning Leo,when I turn the key the system check is OK.
| BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324
ISTR an issue with poor battery connections causing the same problem.
Hi Big Mart,LR told me that they check the battery....I hope .
I had this in my RRS - They needed to replace something, can't remember what but all I do know is that it's a |
It will be great if you can find the work papers or ask them what they did,so I can tell LR what to do !!
| Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434
Mexi
Dear Jonathan,unfortunally that is not the problem.Even when the car is warm,after I wait for the system check etc...etc ,I have to turn the key 3/4 or 5 times before it starts.
I just spoke to someone who had a similar problem - turned out it was the key itself.
OK - so the thing to do is obviously change to your spare key and see if you get the same issue with that one |
Hi Leo,LR is working on the car right now,for the third time.I tried to switch the key....same problem.
| Riggers Member Since: 19 May 2010 Location: Salisbury Posts: 2
Hello,
Hi Riggers,they change the starter motor again...and I did not had any more problems.
