Home > General > New here , small problem with my TDV8
PAULD
Hi guys , very helpful site you have here!
I did do a good search before posting this but to no avail.
My tdv8's drivers seat moves every time you put the key in the ignition and everytime you take it out too , how do you disable this annoying feature?
Many thanks in advance!
Paul
Post #226793 Wed May 27 2009 1:25pm
IIRC use the control stork on the steering wheel column. 2005 Zambezi TDV6 - Gone but not forgotten
Post #226794 Wed May 27 2009 1:28pm
dazsear
Does the steering wheel move too, if so then there is a switch on the left side of the column (the one that you alter the wheel with), I seem to think it's a feature for fat blokes to get in and of the car with...lol
Failing that, with the car stationary go into the settings mode (pressing the left stalk button) there is a mode called 'lazy entry' make sure that is turned off.
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #226795 Wed May 27 2009 1:29pm
C10KO
dazsear wrote:
Does the steering wheel move too, if so then there is a switch on the left side of the column (the one that you alter the wheel with), I seem to think it's a feature for fat blokes to get in and of the car with...lol Daz
Just rotate the swith and disable the automatic mode Thumbs Up
dazsear wrote:
Failing that, with the car stationary go into the settings mode (pressing the left stalk button) there is a mode called 'lazy entry' make sure that is turned off. Daz
This does nothing to do with it mate... Whistle
Post #226798 Wed May 27 2009 1:41pm
PAULD
You guys are brillaint!
Big thanks!
P
Post #226799 Wed May 27 2009 1:42pm
dazsear
I thought if lazy entry was turned on it makes the seat and wheel position alter depending on what set of keys were used.
Very handy if you and the wife both use the car, well providing you use different sets of keys!
Post #226824 Wed May 27 2009 5:42pm
C10KO
Daz,you are absolutey right. That function is very handy when you are using two sets of keys.
But Pauld wanted disable the movement of seat and wheel whenever you turn the engine on/off.
Which needs to be done as you rightly explained in the first half of your post Thumbs Up
Post #226839 Wed May 27 2009 8:00pm
