![]() | Home > Technical > Tow bar wiring kit - Help please |
flight Member Since: 24 Jan 2008 Location: London Posts: 186 ![]() ![]() ![]() |
Please check out the wiring kit below , I brought from ebay . I paid £54 delivered. How easy would you guys say it is to fit? And has any one fitted one and taken step by step pictures of before/after???
Reports are that it's is very very easy to fit 1/2 hour job. The only tricky bit is getting around the weights at the back. 2005 Zambezi TDV6 - Gone but not forgotten
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
The OEM one is easy to fit - this looks similar (but half of the LR kit) and it claims to provide destructions with it....
Okay,
Should be as it looks like the OEM solution. They mount under the cover above the towbar socket (centre rear). A 50p piece will fit the two screws, turn through 90 degrees and lower towards you to remove, that will reveal the mounting point for your electrics. |
Mail Order Ride Member Since: 28 Feb 2009 Location: UK Posts: 131 ![]() |
The LR kit took me just over an hour to fit
L |
CHPR gave me a few spare electrics cover retainer clips FOC with last purchase |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
Just bought similar from ebay an d there's a tutorial on there about the stages fro fitting it - not that I will be doing it but if you are in to diy then have a look. Jaguar XKR Convertible
Interesting!! I tried to talk to Steve or James (who sold me the car) but both were busy Switchboard had a bloke from parts call me back who told me I had to pay for the bits (At 35p each admittedly) If these bits are known to fail Im even more ![]() |
monkey9952 Member Since: 09 May 2007 Location: In A mess Posts: 163 ![]() ![]() ![]() |
Lol broke one of mine too |
