Home > General > Iphone
RR08
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Iphone
Our RRS has recently had a ipod audio connection socket thing fitted to the car by the local dealer, to allow us to connect the iphone to the car.
Has anyone had any experience of using a Iphone with the RRS on board kit, our car is a 08 hse.
Rgds
Emma Range Rover Sport HSE TDV6 - 08 Plate
Post #221975 Fri Apr 10 2009 11:54pm
Also ask the question on our sister site disco3.co.uk From what I understand it makes the ipod controllable using the steering wheel buttons but the downside is that there is no display on any of the RRS screens. 2005 Zambezi TDV6 - Gone but not forgotten
Post #222000 Sat Apr 11 2009 9:37am
Lookers Park Royal
RR08,
Yes I use one regularly. Just plug the phone into the cable, then pres 'NO' when it asks if you would like to put your phone into Airplane model and then you are away.
You will need to set the phone playing either an album or playlist, then you can control the volume and up/down through the tracks via the steering wheel.
The phone will continue to work via Bluetooth whislt you are listening to music.
James Thumbs Up
Post #222004 Sat Apr 11 2009 10:17am
RR08
Am I right in thinking the phone works the same as an ipod but you can't use the connector to make and receive phone calls ?
The problem I get is that when I some times receive a call the phone rings and I answer it on the car bluetooth but the call answers and there is no audio and I end up having to call the person back.
Does anyone else have this problem, I assumed that the connector cable would hook up the car and the iphone together without the need for blue tooth as it goes along..
Help Range Rover Sport HSE TDV6 - 08 Plate
Post #222923 Mon Apr 20 2009 2:06am
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Why not using the AUX-in and a parrot bluetooth-kit? Costs about 50 pounds and works brilliantly! Thumbs Up RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #223691 Tue Apr 28 2009 4:39pm
Jimmy_75000
Welcom,e RR08 / Emma, seems that you are one of the very few women of the forum.
Welcome again! Mr. Green Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #223711 Tue Apr 28 2009 6:04pm
