Home > Maintenance & Modifications > How Do I Remove Steering Wheel
Tboner
Hi all
got a new revere wheel to put on with switch panel in Ebony.
My09 HST , how the hell do i get the wheel off ? taken 4 screw's out of back section but this has not released the centre section or the switch sections ? am i missing something Help ! 2014 5.0SC AB
Gone 5.0 SC
Post #222798 Sat Apr 18 2009 11:56am
PJPR01
United States 2013 Range Rover Sport 4.4 V8 HSE Orkney Grey
Carefully or you might damage the airbag.
There are two small holes on either side of the plastic casing which allow access to the airbag. However, I doubt you have this tool, it's a thin piece of metal about 5 inches long with a small hook on the end used to reach inside and release the airbag. If you have never done this before, I'd be careful.
Once you release the hooks, gently pry the top of the airbag forward slowly and release the wire connections behind, for the steering wheel functions. Then you'll get access to a 16mm bolt...be sure to note the 2 notches to align the wheel again to the spline or you'll have an off center wheel.
The 4 screws you are referring to only provide the casing to attach the steering wheel buttons, but you need to remove the wheel before undoing these. PJPR
2017 FFRR TD6
Former LR: 2013 RRS, 2006 RRS
Post #222800 Sat Apr 18 2009 12:34pm
Tboner
Thanks for the info , yes no tool for that , trip to the dealer and pay a few Pounds will be far better than killing the air bag i think.
Thanks for the great advice. 2014 5.0SC AB
Gone 5.0 SC
Post #222806 Sat Apr 18 2009 1:48pm
PJPR01
Thumbs Up Thumbs Up PJPR
2017 FFRR TD6
Post #222860 Sun Apr 19 2009 2:35am
