![]() | Home > Maintenance & Modifications > DOOR PANEL SUPERCHARGED DECALS- How do I fit them? |
| flight Member Since: 24 Jan 2008 Location: London Posts: 186
RANGE ROVER SPORT DOOR PANEL SUPERCHARGED DECALS
| AndrewHG2 Member Since: 05 Sep 2008 Location: Harrogate Posts: 114 |
They pop out really easily, just lift from the right.
| Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180
Don't they come ready fitted when you buy a Supercharged car? |
L |
Thankyou so much , ur amazing.
Perhaps you`ve been sent the steering wheel badge ? Are they metal ? |
Yes they are metal and I think you might be right...
| mr boombastic Member Since: 08 Dec 2007 Location: NSW Posts: 40
I have also changed my badges to black and had the same problem. The badges are different depending on whether you have a supercharched sport or non supercharged sport. You have either been given supercharched door badges or maybe steering wheel badges. They do not fit in the holes of non supercharged models as they have metal backing. They are also slightly smaller.
| James W Member Since: 30 Mar 2009 Location: North Yorkshire Posts: 40
I've replaced all the green badges in and outside of my TDV8. The s/w and interior door trim badges are made of Tin (with a clearcoat/plastic laquered front).
| kedz Member Since: 10 Apr 2009 Location: manchester Posts: 151
do u think it would be a good idea to use a hair dryer on the steering wheel badge to make the glue soft so i can get it off?? |
| Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054
Carefully drill small hole in centre. Put self tapping screw in and pull gently with pliers to release the metal prongs that hold the badge on.
| hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437
Agreed. There isn't any glue on the steering wheel badge, it's just held in with tin prongs (4 in total). Slowly and carefully prise it out. The new one will need to be stuck on (the prongs are cut off) with glue or 3m. Try and get a wafer thin tape otherwise it will look stuck on.
thank's very much guy's |
| All times are GMT |
