![]() | Home > Maintenance & Modifications > Faulty Bot Cover |
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 114 ![]() ![]() ![]() |
my cover in the boot has gone slack i have opened it up and wound the spring a bit tighter but each time its used the spring gets loose and after 2 uses its all floppy again, any else managed to fix it give me some ideas
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
The thought of you opening your Bot is horrible. If you have a slack bot then you should stop putting things in there. If I were you, I would keep your bot covered to stop anything coming out....(yuk yuk)
If you are still in warranty get it replaced. 2005 Zambezi TDV6 - Gone but not forgotten
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
you're lucky to get 2! |
