![]() | Home > Technical > help , engine system fault !! wont go away now |
| cedarman Member Since: 12 Apr 2009 Location: hounslow Posts: 4
the message engine system fault with reduction in power appeared a week ago on my way to the airport , not having much time to stop to investigate i carried on, switching the car off and on whilst driving as i was in a rush to catch my plane ( i know not very safe ! but i had to catch that plane )
Fairly common. To reset you do a soft reset which involves using the key to lock/unlock/lock/unlock - this resets the system. Yours however has a problem and the best thing to do is when the fault next occurs get LR assist out straight away - do not reset the car, get them to transport to your LR dealer who will then diagnose the proble. Betting is it will be a faulty ECU, clogged up EGR valve or clogged up filter. Do a search as this is talked about in plenty of threads. 2005 Zambezi TDV6 - Gone but not forgotten
just tried the soft reset , it wont work , i called lr assist they are picking the car up tomorrow
| gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136
Please let us know what they say.
the diagnostic is 2 faulty egr valves will take a couple of days to fix
I win today's prize. |
Nice |
My technical background on the matter is far below the "basic" level, so my question is:
I think there are 2
2 valves its a tdv8 , they in betweeen the 2 cylinder heads , i had a look at the computer when it was tested one was stuck at 4.71 % open and the other stuck at 17% open , they would not move either way no matter what position the accelerator pedal was on , they said it was a common problem and lr had plenty of replacement valves in stock !
| mlines Member Since: 10 Dec 2006 Location: UK Posts: 480
I have recently had both EGR valves replaced following all sorts of perfomance problems and alarms.....
| All times are GMT |
