![]() | Home > Maintenance & Modifications > Radio Removal |
| NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246
Hi
Hi
Hi, I have found it, I found it by looking at the install instructions for the retro fit of the Handsfree Phone Kit for the D3 and the RRS
| Didier_Jason Member Since: 29 Nov 2005 Location: Johannesburg Posts: 2
Hi Neil,
| JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898
PM member Prestige Audio they mat be able to tell you how to remove RRS TDV6 Gone but still around
| ryanoz Member Since: 16 Oct 2006 Location: Louisiana Posts: 32
Would someone mind telling me how you got the radio out?
| Andy Member Since: 15 Oct 2005 Location: Shropshire Posts: 1369
Try a hammer. 2002 Discovery Adventurer LE
| pulse Member Since: 02 Sep 2006 Location: Dublin Posts: 15
Remove the silver trim around the top and remove any screws visible. Remove the knob on the gear shilft by pulling straight up then open the arm rest box and carefully remove the the centre console ie: pocket and gear shift this will reveal more screws the aircon must come out before the radio or else you'll break clips |
ok. that's what I figured. I was just going to take a quick peak, but I'll wait till I actually need to do the work. |
| rrmad Member Since: 29 Oct 2005 Location: UK Posts: 44
In the passenger footwell if you remove the side panel you will find a multiplug - can't remeber without looking but you will find a connection from here to aux input. |
| fl-run Member Since: 08 Dec 2006 Location: Reunion Island Overseas Posts: 7
Haven't done it for a bit but you will need to get heater/vent panel out to reveal final fixings, If remember this may also mean top panel of transmission tunnel, its all quite a painful job that lot with bits that will break easy. I dont undertand why you are no picking up from the aux feed in the back, got to be easier. At my age my memory is crap so I take no responsibility for your area being littered with RRS bits - best of luck |
There is no aux wire on the rear central panel on my S version !.... |
Done !!
| All times are GMT |
