Home > Technical > two phones |
mercuryl Member Since: 07 Oct 2008 Location: Sussex Posts: 195 |
The voice dial directory is something entirely separate from the normal phone memory.
Tue Mar 24 2009 8:06pm |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
and it is a long long long and annoying process as you have to speak the phone number by groups and restart if the car does not understand the right number....I gave up as my french accent did not suits! Range Rover Vogue ‘17 TDV6
Wed Mar 25 2009 8:13am |
Frozen of Wiltshire Member Since: 08 Jan 2009 Location: Wiltshire Posts: 66 |
Right, so I can forget about voice dialling(1) as that sounds just too much like hard work for me.
Wed Mar 25 2009 8:38am |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
I think that last one connected makes it. The other is ignored. Only 1 is paired to PTI at any one time. 2022 P440e AB |
Wed Mar 25 2009 9:09pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Must be the accent, works fine for me and was a doddle to set up, can even do it whilst driving |
Wed Mar 25 2009 10:12pm |
It's a bit of a bother but worth it when it is done - I've got about 10 of my most frequent numbers on there. Very helpful. And I have a broad Scottish accent!! I've been mad for flipping years, absolutely years, over the edge for yonks. |
Thu Mar 26 2009 12:17am |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Enter your contacts in the voice dial directory via touchscreen, much faster and no phone number spelling required. Main Menu --> Settings --> Voice Settings --> Voice Add Name. Enter the phone number you want to store using the keypad and touch Add. System will prompt: "Name, Please." Say the name you want to associate with that number after the beep and the system will confirm: "Stored". You can punch in a bunch of numbers in a few minutes that way, and she doesn't even chit chat that much, always a plus! You can store about 50 contacts in the system, but good luck remembering all of them. If the name is too short, it won't be accepted. I tried "Home". "Too short". "Hooooooommmme". "Stored". My daughter laughs like crazy now whenever daddy calls mommy at "Hoooooommmme".
I never tried it myself, but in theory - since only one handset can be connected to the PTI via Bluetooth at any given time - the last phone that connected to the system has priority over another registered handset when both of them are trying to link. So, if you used the BT system last, your phone will connect. If your wife used the car last, her phone will connect and yours will be ignored until your wife manually disconnects hers (or is out of range.) |
Thu Mar 26 2009 2:58am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
on bluetooth last phone paired is the one it pairs with again if you have more than one phone with bluetooth active, PTI in armrest (if you have it) takes precedence over bluetooth
Thu Mar 26 2009 8:51am |
Thanks all, your advice much appreciated - guess I will have a play with the voice directory today. On the bluetooth thing, if the last paired phone takes priority (great suits me perfectly!) is there absolutely no interaction with the other phone in range - if it gets an incoming call while in the car too?
Thu Mar 26 2009 9:15am |
Umbertob !!!!!!!!! You are a hero. I was too lazy to read the manual and didn't know you could enter voice dials in manually like that. I thought you had to do it by voice.
Thu Mar 26 2009 1:14pm |
If you feel the forum has helped you, I know the site owner would be only too pleased to accept a small donation to help support the site's running costs
Thu Mar 26 2009 1:48pm |
No interaction, right. Basically, the second handset won't be able to "see" Land Rover as a nearby Bluetooth device to connect to (or, more correctly, the PTI module won't be hunting for that handset), until the other phone disconnects. |
Thu Mar 26 2009 3:24pm |
cool, thanks again. Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Thu Mar 26 2009 6:32pm |
