![]() | Home > Technical > Sat Nav Master Reset - now I only get Germany!! |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 ![]() ![]() ![]() |
OK - so I have read the manual and still can't get my sat nav to work - I pressed the reset default settings button during a mad moment and now when I put in any address or postcode it only gives me options for germany (I think). Try putting in any postcode for example and you have tp start with a number - bummer!
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
maps normally cover most of europe
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
From the [Destination] screen press the button underneath the Map (which will actually probably have Belgium highlighted rather than Germany), can't recall whether the button says [Change] or something else? Here you go - found pictures!
Another SW - that sounds like genius - will nip out at lunchtime and test it! Feedback in an hour or so
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
once you store your destinations it will navigate you cross border with no problems, I hear "Welcome to the Netherlands" and "Welcome to Belgium" a lot as I live quite close to the border.
My stored destinations are all still in there - just no new ones - will go and try it now! Jaguar XKR Convertible
This is now sorted - many thanks to one and all - I had never noticed that little map before. In addition to sorting my problem I have identified loads of additional functionality to the sat nav that I will now use - (after 18 months ownership...I must read that manual!!)
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
...........and i was just about to say - you only need *Germany* |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Angel that was back in 1945 on the lancaster variant ![]() |
just punching in .....192 .... into the sat nav ![]() Be prepared for a 12 year old lad (and a 50 something) coming to drool over a DBS ![]() Clan Cameron |
have you discovered how to set a new route to a stored address entirely by voice control yet? ![]() |
![]() no matter what I say to it it wants to go to the airport ![]() Clan Cameron |
