![]() | Home > Technical > 2005 rrs supercharged wont start. |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Mate, I would assume that you have flatten the battery...
Yup just a flat battery by the sounds of it. 2005 Zambezi TDV6 - Gone but not forgotten
ridgey Member Since: 07 Mar 2009 Location: colchester Posts: 7 ![]() ![]() ![]() |
thanks mate, i just tried again and still nothing but this time same things with lights but some codes came up, hdc code, suspensions code and special programs, do you think this could all be besauce battery is drained. and would they stop the engine from starting |
All those warnings are sure signs of a low or flat battery, it's one way the car tells you the battery is in a poor state of charge - RRS and D3 hate low batteries! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Yes those messages are typical when battery output is below par. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
thank you for your help guys i will charge it in morning and get it checked to see if i need a new one. |
yep flat battery it was, all ok now thankyou |
jammy Member Since: 04 Jul 2008 Location: East Midlands Posts: 46 ![]() ![]() ![]() |
Same happened to me
Putting your keys in the ignition "wakes up" all the elctrical systems in the car, doesn't just allow you to listen to the radio. Putting the key in the ignition also charges the internal battery in the fob, so when all the system think they have to be ready to go there's a fair old drain on the battery. IIRC you don't need the key in the ignition to use the audio anyway, just press the on button and it will come to life for 30 minutes and then switch off, just press the on button again to bring it to life. What you won't be able to do is annoy the neighbours by listening to the audio at high volume, you get so far up the loudness scale and it goes no further and the display shows Low Energy Mode or something similar 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
