![]() | Home > General > Sea Sick .. |
Have you checked that all the windows and the boot sections are fully closed and the seals are good? You could be drawing exhaust fumes into the car. There are a few people who cannot travel in the gas suspended Citroens because the magic carpet ride gives them motion sickness. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| AndrewHG2 Member Since: 05 Sep 2008 Location: Harrogate Posts: 114 |
Will check first thing in the morning! I hadn`t thought of that, thanks Very much Tim. |
| C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136
Andrew a stupid comment, but have you not tested the car before? Did you feel the same? |
| Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902
how weird - met a new member yesterday at the meet (Bob.) and he was have a similar experience |
| Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554
Andrew, if the car is used, maybe the dampers (shocks) need replacing.
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
What did you come from? |
Leo he is driving a V6 so I am not sure whether he has DRS.
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
i don't see what this has to do with sea sickness (NWS)
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391
check wheel balance. if out of balance by small amount (i.e. not enough to cause vibration you can feel through the wheel) the subtle movement in the wheels/body can cause a motion sickness type feeling, exagerated in the RRS because you are sat up high |
Hi Coko, yeah I had a quick test drive and everything seemed fine at that stage, went on motorway and b roads. Was probably distracted or just buzzing from the possibility of getting a RRS. Have been ok today though, hopefully it was just a blip ??? Fingers crossed |
Eek it`s spreading |
Yeah it`s a 3yr old, will add the shocks to my list of possible suspect, cheers |
I came from a 2002 Toyota Celica, so that could also be added to the mix The celica was alot closer to the ground and was very sharp/firm, I guess I am now suffering from altitude sickness |
| All times are GMT |
