Home > Maintenance & Modifications > Nav-TV video in motion
incomis
Bulgaria 2006 Range Rover Sport TDV6 HSE Java Black
Two weeks ago I buy and install this VIMCANROV-LR which is www.nav-tv.co.uk "Video In Motion" Interface CAN for Land Rover Discovery 3 / Range Rover Sport (MOST) system (http://www.nav-tv.co.uk/products/vimcanrov-lr?car=133).
Today I found that on NAV screen the mode of gear box is always on "N". When I change to D, or R on navigation screen always show "N". Is this normal or I have problem with nav.tv interface?
My car is Range Rover Sport 2006 2.7 TD, HSE, RSE, winter pack
Thank you in advance.
Post #213723 Wed Feb 25 2009 9:24am
DiscoStu
Is this how the unit works, by fooling the car into thinking it's always in neutral? A D3 not in drag....
http://www.youtube.com/watch?v=GEr9N6EGFNg...Sv8zqkav9F
Post #213725 Wed Feb 25 2009 9:41am
incomis
This is my question too ...
Post #213726 Wed Feb 25 2009 9:45am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
If you have the active Nav-TV hack, that's normal. The module does indeed trick the electronics into thinking the car is in neutral all the time, and the trick spills over on the 4x4 Info screen. Other than the "N" displaying at all times, no harm done. The remaining sensors still indicate what TR mode you are in, if you are in Hi or Low, HDC, lockers, compass, suspension and steering angle graphics all work, etc.
Post #213781 Wed Feb 25 2009 4:51pm
Bobby
Could this LR enhancement be for the same purpose...?
http://www.rrsport.co.uk/gallery/albums/us...20Move.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #213876 Thu Feb 26 2009 12:00am
umbertob
Every time I see that "Navigation on the move enhancement" bulletin I get royally pi Censored d as it's still not available to us in North America, and it most likely never will be, no doubt thanks to our litigious society. Big Cry Nevertheless, I believe that modification would do nothing to correct the Nav-TV induced issue above, since the satnav uses different signals (a combination of wheel speed sensors and GPS communication) than the RSE/video system hacked via the Nav-TV module, to determine if the car is moving or not.
Post #213881 Thu Feb 26 2009 12:30am
incomis
Thank you. This sound good for me. Best regards.
Post #213889 Thu Feb 26 2009 7:56am
