![]() | Home > Technical > TDV8 HSE - Drivers seat movement |
stonosam Member Since: 12 Feb 2008 Location: Sydney Posts: 32 ![]() ![]() ![]() |
You stealer should be able to get hold of the bulletin fairly easily. Don't let them tell you otherwise. The real problem is going to be getting the parts. My stealer has had them on back order since the beginning of January and there is still no sign of them arriving anytime soon. |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
Stonosam
What did you replace the old one with? |
I have a 2009 TDV6 in Buckingham Blue with Almond coming as a replacement courtesy of LR with a "token" payment from me because of all the component replacements in such a short time (8 months). Should get it this week sometime I think. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Wow! that's really nice. I hope that this one is a better all round experience for you.
Wozz Member Since: 28 Dec 2008 Location: Cheshire, United Kingdom Posts: 826 ![]() |
I am noticing the same problem in mine an dit has only clocked up around 1k miles.
tomw Member Since: 10 Feb 2009 Location: Lincolnshire Posts: 19 ![]() ![]() ![]() |
Anyone got an answer to this yet? My driver seat is loose again.
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
The matching TSB for North America regarding this issue came out just a few days ago. I am thinking the part #s would be the same for NA and ROW. Posted copy of the bulletin here for North America owners:
After filling in my Land Rover customer satisfaction survey on line on Friday last week, and mentioning the seat movement - my dealer called me this AM and I have booked the car in again for them to take a look.
Hi Tomw
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Is is possible to just change the rubber stops? Maybe get something made from an aftermarket supplier? |
At this point they are looking at coming up with a solution, but I don't think it is as simple as coming up with alternative rubber stops otherwise they would have just sent them as opposed to sending an entirely new rail. |
Yep, it must be a widespread problem because my new 2009 (2nd RRS) has also started to move. My past experience is that application of the TSB alone won't fix the problem. A combination of TSB and new rails did seem tp fix the problem on my old car but I didn't have it long enough to carry out a thorough evaluation Gone - 2008 Stornoway Grey RRS 2.7 TDV6
I have a 09 loan car 300km on the clock and it is doing the same thing as well.
