![]() | Home > Technical > Lower than Access Height |
| deadly Member Since: 29 Nov 2008 Location: lancashire Posts: 9
hi Steve,try one with side steps on.Its just a little help up.Having three young children they struggle to clamber in without side steps. |
| SteveP Member Since: 18 Feb 2009 Location: England Posts: 3 |
She's had a look at that and unfortunately, with a back condition it doesn't help. |
What about putting the car into access mode, and then moving the drivers seat as far back as possible and lowering it to it's lowest setting. It's slow but at least the seats are motorised 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
Lower the suspensions from off-road to access height, then raise them back up to off road. Repeat at least 12 times, in rapid succession. Ignore the warning chimes and flashing amber lights on the dash. The compressor should overheat, the height sensors will fail, a valve somewhere will get stuck and before you know it you will be on your bump stops. Invite the wife to come aboard. |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
| DiscoStu Member Since: 10 May 2006 Location: Essex Posts: 47
Dig 4 holes in the drive?
| RonnieG Member Since: 16 Mar 2008 Location: Armagh Posts: 207
when my wife was heavily pregnant she had a bad back and limited movement she found access height and the seat fully lowered and back the easiest way ps we have side steps and she says there would have been little chance of her getting in without them. |
What if the dealer enabled the transportation mode to be used? Is that a viable option maybe? |
| Sexy Pauly Member Since: 24 Aug 2008 Location: LAN DAN MATE Posts: 698
buy a lowering module u can make it go lower than normal settings RR Sport supercharged 06
Steve, I am pretty sure transportation mode needs to be enabled (or disabled) through Land Rover diagnostics software hooked up to the car. It's either / or, meaning that all other suspensions modes are unavailable until transportation mode is turned off.
Yes, just go buy a T4/LR IDS.
| ste777 Member Since: 16 Feb 2009 Location: United Kingdom Posts: 5
Come on people , think outside the box ! Get her to wear platform shoes then she`ll be that much closer to the seat. ste777 |
Build a wheelchair ramp parallel to the drive so you can park beside it in access mode with the door in line and level with the high end of the ramp................... is that far enough out of the box? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
would those automatic fold out FFRR steps work with a RRS |
| All times are GMT |
