Home > Maintenance & Modifications > Door Trim Removal
slim_sane
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Door Trim Removal
Has anyone taken off or know how the bottom door trim (i.e. the side skirt) part of the exterior trim is removed?? Question I had a quick search but not really found a definitive answer.....
Post #212548 Thu Feb 19 2009 4:29pm
PauloAmore
Scotland
Grab it and yank it up.....
- It is clipped on and comes off with a pull.
You may want to remove the door pillar cover first if that impedes removal. 2022 P440e AB
Post #212615 Thu Feb 19 2009 7:30pm
Do a search for "yellow+poppers" 2005 Zambezi TDV6 - Gone but not forgotten
Post #212618 Thu Feb 19 2009 7:50pm
slim_sane
Thanks guys!!! Thumbs Up
Post #212668 Thu Feb 19 2009 10:39pm
PJPR01
United States 2013 Range Rover Sport 4.4 V8 HSE Orkney Grey
The clips are actually horizontally positioned, so yanking up may lead to breakage...if you pull horizontally backwards I believe, it should come off with less force...and fewer yellow poppers...
Very Happy PJPR
2017 FFRR TD6
Former LR: 2013 RRS, 2006 RRS
Post #212719 Fri Feb 20 2009 1:23am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Trim removal tools are essential and will stop breakage, have a look here
http://as-essentials.co.uk/index.php?main_...cts_id=445
Post #212736 Fri Feb 20 2009 10:02am
