![]() | Home > Maintenance & Modifications > Sat Nav voice |
I assume this "button on the screen" that you push is the one that repeats the verbal instructions if you need to?
| tomw Member Since: 10 Feb 2009 Location: Lincolnshire Posts: 19
That's right Tim, I want the audible instructions button to work when press it - but for verbal guidance to be silent at all other times.
| mercuryl Member Since: 07 Oct 2008 Location: Sussex Posts: 195
Activate the voice command function from the switch to the left of the steering column and say,
Thanks guys, I think I've cracked it now by pressing a few more buttons...it was probably more obvious than I originally thought.
When you have sussed out what you did let us all know please Tom, that voice can be a pain at times!
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 184 |
If you fancy a bit of fun when you are in your friends car :-
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355
It's actually quite simple: On the screen which appears after you have pressed "Agree", it shows the 4 black boxes: Destination Entry etc. In the lower right hand corner there are 2 small icons. Press one to have voice activation on, press the other to have it off. Once off, you can then choose to hear the voice command at any time by pressing the lower right hand icon on any map screen, and it will provide you with the guidance you need. 2017 FFRR TD6 Former LR: 2013 RRS, 2006 RRS |
Thanks PJ |
| McBunny Member Since: 18 Sep 2008 Location: South Posts: 679
Well, I just wanted to state that. I'm a technical dumbhead but even I found that function within seconds... |
| All times are GMT |
