| RRSPORT.CO.UK | ||
|  | Home > Technical > Hardwire GPS Speed Detector |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    |
 Well just bought the new Talex GPS Speed Detector ( http://www.talex.co.uk/ ) and I want to hardwire it.
|  Mon Feb 16 2009 3:30pm |
 Does the microGo display the actual speed limit of the road you are on all the time, the Talex doesn't I have since found out, only when in camera detection areas, maybe I ought to change mine, where and how have you fixed it to the dash, have you tested it yet for detection? https://www.plus.net/refer.php?strReferral...d093cba6a7 Gone - RRSPORT TDV6 HSE Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course. | ||
|  Mon Feb 16 2009 4:26pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | The mircoGo displays your speed as a default setting, then when approaching a camera it starts to beep if your going too fast, displaying your current speed, the actual speed limit in a circle and a decreasing bar, showing how far from the camera you are
|  Mon Feb 16 2009 5:07pm |
| Richchad Member Since: 04 Apr 2006 Location: Oxfordshire Posts: 285    | So, like the Talex unit it doesn't display the speed limit until you are in a detection zone, hmm maybe I will keep the Talex after all, although the MicroGo does have a neat looking display.
|  Mon Feb 16 2009 5:18pm |
| lemm Member Since: 03 Jan 2008 Location: London Posts: 135    | re: location of power... i cheated and pulled a switched live through from my NAV.TV unit.  Connected this up a new cigarette lighter and hid it behind the panel holding the light switch. Loads of space behind this panel, plus its then close to my final destination on bottom right hand corner of windscreen.. it's a fairly tight squeeze to pull the mini-usb through, but with a bit of perseverance you'll be fine.
|  Mon Feb 16 2009 5:35pm |
 Thanks Lemm, so have I got this right, you found a switched live behind the light switch panel and connected a another cigarette lighter to it to plug in your Sat/Nav/TV unit? ...will take a look tomorrow...thanks for that.  https://www.plus.net/refer.php?strReferral...d093cba6a7 Gone - RRSPORT TDV6 HSE Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course. | ||
|  Mon Feb 16 2009 5:48pm |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355      | http://www.rrsport.co.uk/forum/topic10937....r+detector
|  Mon Feb 16 2009 6:05pm |
 Thanks for that PJPR01, I found that one in my search but unfortunately it is to connect up to the centre light panel not the dash, thanks anyway...  https://www.plus.net/refer.php?strReferral...d093cba6a7 Gone - RRSPORT TDV6 HSE Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course. | ||
|  Mon Feb 16 2009 6:10pm |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355      | Oh...I see now.  Hhmmm...let me check around again.
|  Mon Feb 16 2009 6:15pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | but its given me a idea for the installation of mine in the FL2, cheers for that PJPR01 | ||
|  Mon Feb 16 2009 7:37pm |
| lemm Member Since: 03 Jan 2008 Location: London Posts: 135    | not quite... power for nav unit is pulled in from rear. A pain, but part of a second project to install a second battery. Easiest place to pull a new power feed in the front is from the existing cig lighter. RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, Stormer Alloys. (+ 19" MTR's for playing in the snow!) | ||
|  Mon Feb 16 2009 10:05pm |
| Posting Rules
