| RRSPORT.CO.UK | ||
|  | Home > General > Any advice on defrosting screenwash jets? |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | PA, don't you have heated jets?
|  Mon Feb 09 2009 11:50pm |
| Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905    | If all else fails, leave the Sport stationary engine running when warm. That'll thaw them out. Runner up - 2009 Best Avatar Award  | ||
|  Tue Feb 10 2009 6:04am |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    |
 Hmm. well, I should so. But they don't feel warm to the touch. 2022 P440e AB | ||
|  Tue Feb 10 2009 8:54am |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | They don't get that warm Paul. They are heated but not HOT! Another thing to try is to squirt some aerosol de-icer (kust a tiny amount) on each nozzle and leave it for a couple of minutes.  Is the tank frozen or are the lines frozen?
|  Tue Feb 10 2009 9:01am |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    | LOL....
|  Tue Feb 10 2009 9:10am |
 It's because of this, and to reduce cold start emissions, that the TD engines have the FBH. The high carbon content engine block is so thermally efficient that in cold weather you don't get warm air into the cabin for a very long time without the FBH, which is set up to cut-in automatically when the outside temperature is less than 5C, it still takes time to heat the cabin with it running, just you get warm air within 2-3 minutes instead of waiting hours. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW | ||
|  Tue Feb 10 2009 9:17am |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | I've just moved my car off the drive - all scooshers frozen solid and nothing coming out even after running the engine long enough to get warm air to thaw the ice on the screens. The water bottle isn't frozen as there is fluid water right up into the neck of the washer bottle neck. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Tue Feb 10 2009 9:36am |
| Money Money Money Member Since: 09 Feb 2009 Location: England Posts: 32    | Tried usuing my screen wash int he snow and nothing. Checked the fuse - Blown!
|  Tue Feb 10 2009 4:33pm |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293    | OK....
|  Tue Feb 10 2009 4:39pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Checked the Halfords screen wash I have today - instructions give dilution directions and they say that neat liquid has strong enough antifreeze to work down to -15C. 50% is ok down to -5C. I think part of the problem is that the front screen washer lines run between the steelwork and the under-bonnet insulation so you are on a looser even with the nozzle heating as the insulation also stops the engine heat from getting to the lines and the steel will be freezing them too.
|  Tue Feb 10 2009 5:57pm |
| McBunny Member Since: 18 Sep 2008 Location: South Posts: 679      |
 +1!   (Althoug usually parked in the garage but I didn't have an issue when it was parked in the mountains for two days at -18.   As to answer the original question:
 Buy a garage, park the RRS inside it for one day, done!    RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration   | ||
|  Wed Feb 11 2009 9:50am |
| Posting Rules
