Home > Maintenance & Modifications > HDC and airbad fault!!!
cowey101
Hi, I have a 55 plate TDV6 and the HDC fault comes on everytime I start the car and now the RED airbag fault sign has appeared permanently.
I have tried the HDC and it works fine but the fault still re-appears???
Has anyone had issues with any if these and if so???
I will call in stealers when I get time Big Cry
Cheers Java Black TDV6 HSE - Java Grandes Marques 1/18 - Ducati 749s
Post #210378 Sat Feb 07 2009 5:51pm
BigMart
Hi Cowey,
HDC on its own usually indicates a problem with ABS , sometimes a $hitty sensor.
the airbag might be a bit more sinister....
needs plugging in.
Fingers crossed
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #210379 Sat Feb 07 2009 6:08pm
PauloAmore
Scotland
Bet you need a new battery (mine wrong when started after cold nights).
Not sure about the airbag though. 2022 P440e AB
Post #210400 Sat Feb 07 2009 9:05pm
Tangy
2005 Range Rover Sport Supercharged Java Black
I have the same problem with the HDC. A fault comes up on the dash but when i press the HDC button, it still works......
Post #210406 Sat Feb 07 2009 11:09pm
