![]() | Home > Australia & New Zealand > Suspension Knock |
| baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273
hi bt is the knocking coming from the front when you go over a bumpy road or a pothole |
| Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054
Now a common problem.
| BT Member Since: 31 Jan 2009 Location: Perth Posts: 3
Gday baxc. The Knock comes from the front in the right but occasionally occurs in the left. It accurs when I hit some rough road. It is shocking off road and sounds as though a stut is broken. Would not want to go to far off road. |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382
BT - there are quite a few threads on these issues outside of the Australia and NZ section if you do a search. Hope they manage to fix yours soon! let us know how you go with your local dealer! |
Try reading up on this post BT, there are some others as I said if you do a search on the forum:
hi bt it sounds like the same problem as mine it needs new anti roll bar bushes lr do a new modified 1 now and new ball joints had mine done 2 weeks ago under warranty nocking has completly gone now hope you get it sorted m8 |
Just a quick update on my RRS TDV8 suspension knock. Took car to another dealer for second opinion. Dealer upgraded software and re adjusted rear door (another matter). Was not impressed with the update so I took the car for a run to the Pilbara and put it through its paces on the access roads to the Georges and surrounding tracks near Tom Price and out onto the Burrup peninsula. The knock still occurs in the right front (clunk some times) but is now over shadowed by the the rear door that rattles so badly that it sounds as it may fall off (cant win). I wonder if its possible to shoe horn that lovely TDV8 into a X5. |
| All times are GMT |
