![]() | Home > General > 4x4 Information Screen |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
When I enter sand mode etc, a couple of unlocked padlocks appear on the transmission graphic.
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
Hi Paul
Cool.
could be the Haggis ahead alert system |
Those three legged creatures will take much more than LR's Radar based ACC system to catch.
Our test car was TDv8 HSE Maybe rear diff lock is standard i only have a TDv6 HSE on which is only an option MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Cool.
Unfortunately the e-diff is an extra cost option on the TDv8. I think Josh is the only person who has ever specified it as an option!
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Got one on mine |
Gary Member Since: 22 Jun 2006 Location: Essex Posts: 268 ![]() ![]() ![]() |
iDiff is an option and is automatic (no buttons), was a £500+ option on mine 2006? |
TheMole Member Since: 26 Aug 2008 Location: Somewhere Posts: 43 ![]() ![]() ![]() |
thats to switch on the Alert part of ACC without cruise control being on I believe |
Tyre pressure monitor is not on mine.
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
All RRSs have electronic center diff lock as standard equipment, therefore we all have those 2 padlock icons on our 4x4 monitor. If you don't have LRD, the center and rear padlock icons will both turn red/locked - concurrently - when the center diff locks. If you do have the extra cost electronic rear lockers, the two differentials will open and lock independently of each other, therefore the icons on the monitor will reflect this. So, while offroading your center icon may turn red while the rear one stays green, or the other way around. Both center and rear diff are controlled via electronic modules, so you cannot manually engage or disengage either. Short of sliding under the car to check if there is wiring sticking out of the rear diff housing, the behavior of those padlock icons is the easiest way to tell if you have LRD or not. |
Now, that should have been on the ... things you didn't know about your RRS thread.
