![]() | Home > Maintenance & Modifications > PS3 with Internet Connection in RRS |
bryanlittlefair Member Since: 03 Oct 2008 Location: Bury St Edmunds Posts: 39 ![]() ![]() |
The router isn't broadcasting on gsm or wifi until it recieves a request for an internet address and is tickled by the rj45. cable from the ps3. So the kids swimmers are safe |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
something about computers? |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
the PS3 is broadcasting on bluetooth and polling on wifi when it is on even if you are not using it. Nice install by the way ![]() Clan Cameron |
The blue ray discs work fine, just watched a bit of planet earth, they obviously arent Hd 1080P bit they are the same as any other DVD on the screens and work fine. The best bit is having the inverter there, as I have just swapped out the PS3 for an xbox360 and it is interchangeable, the xbox360 is renowned for not liking being on the move, the discs can scratch. The PS3 works a lot better because of the way it loads the disks. However I was sat there doing some tests with the ignition on but without the car started, and the inverter alarm went off, just FYI a PS3 can drain a RRS sport battery in about 15 mins....... I had to switch everything off and it just turned over ........ learned that lesson quick..... |
You need to do what the guys with electric winches on the front do - fit a second battery and a split charging system to provide the power. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
PS3's are notorious for the demand for juice.
wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99 ![]() ![]() |
What model is the GSM to Wifi Converting Router,? Bluetooth Exchange www.bluetoothexchange.co.uk |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
I feel really slack now...... I have had my PS3 install fitted for a week now and still not got my finger out and took some photos for the group. |
the router is a cisco linksys GSM router, I will post the exact model tmrw, as its raining outside |
Has your PS3 got wireless capability of it's own?
Hey Daz, yeah the PS3 has wireless capability. but it cant connect to anything on its own without an access point, if you are packed in a public hotpsot zone, or outside your house with a wireless router then fine you can get online. But my method is permenant internet access wherever there is mobile phone coverage. The PS3 needs to wirelessly or cable connect to an internet router in order to get online |
I see, now it all makes sense.... not sure if I would use the internet on the PS3 unless I could tap into free wireless, say outside a McDonalds... I use my Blackberry Storm for mobile internet stuff.
lemm Member Since: 03 Jan 2008 Location: London Posts: 135 ![]() ![]() |
Can you confirm the router is a Linksys WRT54G3G???
cyberjes Member Since: 12 Jan 2008 Location: Prague Posts: 167 ![]() ![]() |
clean install. i like it! |
