Home > Technical > lazy entry problem |
rrspoland Member Since: 04 Dec 2008 Location: Warsaw Posts: 123 |
I have a problem with lazy entry. I set it to on position on the computer, but nothing happens. I asked at the dealer and they said they switched it on, but after I left the service it actually still didn't work.
Wed Jan 07 2009 12:38pm |
Once lazy entry is switched on, you then need to turn the key to position I or II on the ignition, move your seats and mirrors to the desired location then press the MEM button followed by one of the numbers. The car will beep, and a message appears on the dash display.
Wed Jan 07 2009 12:44pm |
thanks for the info. but from what you wrote it means that lazy entry is that the seat will automatically move to my stored position once I use "my" key. is that right? I have an infiniti fx and lazy entry is the option that when I open the door the seat moves fully back for easier entry and when I close the door and put the key in the ignition then the seat moves to the stored position. so which one is it? if it is what I undesrtand from your post then it is really pointless. My name: Patryk RRS 4.2 s/c Rimini Red |
Wed Jan 07 2009 1:04pm |
Lazy entry settings are coded to each key and allows, for example, you and your wife to both have your own settings coded to your own keys. It's not like the equivalent "lazy entry" in some other cars where everything moves out the way (including steering column) for you to get in.
Wed Jan 07 2009 1:22pm |
I see. Thanks for the info. Now I undesrtand, why it "didn't work" My name: Patryk
Wed Jan 07 2009 3:19pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
You can always program the Key so the seat is all the way back when you get in and the push memory 2 for you driving position RRS TDV6 Gone but still around
Wed Jan 07 2009 3:20pm |
Did you have three Shredded Wheat this morning or something?
Wed Jan 07 2009 3:40pm |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
AKA Geriatric Entry... I think that feature is available on newer Sports (those fitted with power tilt/telescoping steering columns anyway.) I've experienced it on a new LR3 here and it's a bit disconcerting to see everything moving up and away when you remove the key from the ignition if you are not used to it, but I don't believe Land Rover gave it a "name". You can disable it. |
Wed Jan 07 2009 4:40pm |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 |
Yes, RRS from 2008.5. Used it few times at the beginning, but the novelty wears off quickly, and I'm not "fattish" like some around here , can get in and out easily, so I disabled it '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil |
Wed Jan 07 2009 5:29pm |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
yea and i found sometimes if you were too quick and start the car the seat stops moving half way through the positioning. Im pretty sure i saw a 'lazy entry' option in the settings on the dash (flick through the OBC while stationary). I turn it on and off via the electricly adjustable steering column stalk though, so not sure what the menu option is for. |
Wed Jan 07 2009 6:53pm |
NO!!! I had 4 RRS TDV6 Gone but still around SL55 AMG 760Li Alpina BMW 535D M Sport BMW X6 XDrive35D BMW 320D Coupe M Sport And A Van For Rex! WINNER - 2008's Idler Of The Year WINNER - 2008's Comedian Of The Year WINNER - 2008's Funniest Incident I love boobies i love boobies i love boobies cuz i'm a big kid now! (Come on everybody sing with me you know the words!) |
Wed Jan 07 2009 7:07pm |
stonosam Member Since: 12 Feb 2008 Location: Sydney Posts: 32 |
Does anybody know if the steering col. adj. is in the auto position whether the seat as well as the streering wheel moves or just the seat? |
Thu Jan 08 2009 4:40am |
If you have the electric steering column adjustment switch you leave it on "Auto", I think. If you don't want seat and wheel to move, you flip the switch clockwise to the Geriatric off position. |
Wed Jan 21 2009 7:42pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Thanks Umbertob will give it a try |
Wed Jan 21 2009 7:54pm |
