Home > Maintenance & Modifications > Anti vandal glass film |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Yep asked my guy about this security stuff he said it's not good as they can still brake the small windows!
Sat Jan 10 2009 12:47am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
I've had the Pentagon version of this fitted on previous cars, called Supaglass. All sized windows except front and rear screens. They can't do the rear screen because of the heated elements and the only thing that would prevent any others might be if there is a lot of curviture of the glass.
Sat Jan 10 2009 3:41am |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
I am not sure to be honest. Especilly when it really works only on the "moving" windows.
Sat Jan 10 2009 8:23pm |
I had it fitted to small non moving windows on a Jag and a Merc. And all moving windows.
Sun Jan 11 2009 7:07pm |
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 |
It's not really "anti-vandal" but security. It's meant to stop attackers smashing the side glass at the lights, or similar, and ripping your g/f's diamond necklace off (or worse!) Worst case is turning ignition off and grabbing the keys, then you are really in the sh*t if it's 2 in the morning in some dodgy area. Nothing, even security film will stop the hard-case vandal or thief, short of full diplomat-level armour. Good idea in today's worsening situation, in my opinion, when street-crime against the apparently privileged will inevitably increase. |
Sun Jan 11 2009 9:56pm |
jambo Member Since: 31 Aug 2008 Location: Stoke on Trent Posts: 59 |
I've had the Pentagon film fitted to our vans at work on side windows and front quarterlights. Anything i can do to stop someone trying to smash the windows at traffic lights and hijack my stock is a bonus as far as i'm concerned. Chose the pentagon one after taking part in a demonstration at the local merc dealers - after 5 minutes with a baseball bat i was still no closer to getting through the window very impressive ! 2005 TDV6 HSE Zermatt Silver Ebony Interior Sunroof, RSE, Side Steps
Sun Jan 11 2009 11:22pm |
You are absolutely right guys, it is definitely a no brainer for me...
Mon Jan 12 2009 12:22pm |
Coko,
Mon Jan 12 2009 5:59pm |
Josh,
Mon Jan 12 2009 7:44pm |
Do they do it in their own workshop?? RRS TDV6 Gone but still around
Mon Jan 12 2009 7:45pm |
Yes mate...
Mon Jan 12 2009 8:36pm |
Coko - I'm sure it can be applied to non moving windows as well, it better be because they've put them on my quarterlights on the vans - i think the only reason fitters like to say moving windows only is because it is easy to fit if you can remove the glass from the surrounds. It is possible to fit to static windows if it is the same style of fitting as privacy film is, but it can be a right pain getting the right size and fitting it in akward places.
Mon Jan 12 2009 8:53pm |
Mon Jan 12 2009 9:02pm |
I though they mat send your car off to a tinter and just add they bit to the price? RRS TDV6 Gone but still around
Mon Jan 12 2009 11:48pm |
