![]() | Home > General > Parking Heater / Stand Heizung |
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 ![]() ![]() ![]() |
So where do I get one of these timers installed? Is there a LR part number I can ask the stealer to install, or is this something I have to do myself (not really a mech head)?
Yes please do |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Going to be expensive!
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Mmmh |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Your not wrong there if the dealers in Switzerland, if the price of a pizza is anything to go by at Geneva airport last night which was 25chf ![]() |
Paid £19 for a Vodka red bull out there |
Well it was more had to then wanted to RRS TDV6 Gone but still around
Out in Morzine in France over the weekend snowboarding,
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 ![]() ![]() ![]() |
Good luck, I have the LR "Russia Kit" fitted to my D3, it consists of a Webasto 1533 timer and enables the FBH to be turned on at a preset time and warm the engine giving quicker defrost and cabin warm up once the engine is started. This is further upgraded to enable the FBH to be fired up by phone. The car electronics must be "asleep", if they are awake then the car will override the Webasto timer and shut down the heater. This kit is supplied to LR by Webasto and although several have claimed to speak to peeps at Webasto that in turn claim to be able to upgrade it to a "Full Parking Heater" (by which I mean it will also run the car ventilation to warm the interior without the engine running), I have yet to see/hear of a specific Webasto install that does this. The issues are with the A/C vents, the cabin fan motor is also not a straight 12V type. I understand that Webasto got a solution running but could not stop the A/C logging errors etc so would not move it to sale. LR have subsequently stopped sale of the LR kit it seems, in any country that, in their view, doesn't require it. Search Disco3.co.uk and there are many threads on the subject. The standard purpose of the FBH is to supplement the engine heat to bring the engine up to temp quicker in cold conditions and to maintain coolant temp and hence heater output into the cabin if the engine cannot (left idling, my D2 temp would drop as the engine is too thermally efficient and under low load cannot maintain the correct engine temp for good heater output, the TDV6 and TDV8, in common with lots of modern diesels, are the same.). The Russia Kit was developed to overcome a particular cold start issue in Russian type winter conditions, hence the name. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
As some of you have guessed the option from my stealer here in Liechtenstein is not cheap, but then again, not crazily expensive either.
