Home > General > washer fluid |
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 |
Yes, there is warning: "Low washer fluid" RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
Fri Jan 09 2009 11:09pm |
jamiepyoung Member Since: 08 Dec 2007 Location: Finchampstead Posts: 31 |
It's the fuse. |
Sat Jan 10 2009 2:37pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
It is - i had this - headlamps ok screen inop - good luck changing it you'll be better off buying a bag of spares from halfrauds IIRC rather than trying to get to the spares....
Sat Jan 10 2009 3:09pm |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
Easy enough to change the fuses...use a pair of long nosed needle pliers - GENTLY!
Sat Jan 10 2009 4:11pm |
I think the supplied fuse changer tool works well it just cannot get to the spare fuses IIRC |
Sat Jan 10 2009 4:42pm |
