Home > General > Parking Heater / Stand Heizung
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
All,
Living in Switzerland, and it being so damn cold these days, has made me think of the good old "oil heater" I had in my Land Cruiser when I lived in very cold climate, so I looked around, and found a whole bunch of posts regarding the Webasto solution over on the D3 forum, and even some posts here in the RRS one.
So, what do I have in my TDV8, just a standard pre-heater, the so-called FBH (Auxiliary Heater)? And if so, can it be made to turn on before I come out and start up the engine? And, how do I check if I do have this installed?
And, is it possible to "upgrade" this system to become a complete Parking Heater solution, and if so, how?
Thanks in advance,
KB RRS TDV8, black with ivory.
Post #204810 Sat Jan 10 2009 1:28am
Wozz
There was a post recently about this. I am sure someone said they had geared it so they could use their phone to start the heater. Either that or I have been dreaming about reading forum posts! WINNER - 2009 Best Newcomer Award
'09 TDV6 XS Stornaway Grey
'06 BMW 730 D SE (Gone)
'08 A4 TDi SLine Avant (Gone)
Large pack of Flake Cakes (Gone)
6 pack of Guiness (Gone)
Post #204814 Sat Jan 10 2009 1:54am
No your Right Wozz it was VA that posted a link that you can preset the time or text to heat up
Think he said it was £400 fitted RRS TDV6 Gone but still around
Post #204816 Sat Jan 10 2009 2:01am
Josh
Re: Parking Heater / Stand Heizung
Killerbob wrote:
All,
KB
No can't be done. But with the timer it will warm the engine up for you but not the cabin till you get in and start the engine. TDV6 - gone
TDV8 - gone
Post #204821 Sat Jan 10 2009 3:28am
Killerbob
OK, so we may, or may not, be able to upgrade the system to a parking heater with, or without, a trigger.
But, the existing solution, this FBH, when does it turn on?
I understand it turns on at a predetermined temperature (some say 5 degrees), IF there is enough diesel in the tank, AND the interior climate system is set for automatic, even if/when the engine is turned off. Also, how do you know it has been turned, or is turned on?
Post #204863 Sat Jan 10 2009 11:09am
Josh
Turns on at 5 degrees.
How do you know it's on?...........usually you can smell the diesel inside the cabin and you will see the exhaust smoke coming out of the wheel arch. TDV6 - gone
TDV8 - gone
Post #204913 Sat Jan 10 2009 6:51pm
kam100
Yep looks like this:
I want a preheater for my Viano/S Class and 7 series.. and will pay whatever is needed so i don't have to sit on freezing cold leather.. i HATE IT!!
Post #204933 Sat Jan 10 2009 9:20pm
kam100
Post #204934 Sat Jan 10 2009 9:24pm
Killerbob
OK, so it should be easy then.
I have found the Webasto heater in the engine compartment, and currently it is -10 degrees outside, and the car has been turned off for 4 hours, so it should be kicking in. However, there is no smoke, and it does not smell like diesel, so how can I see if it is working (if I turn the key and get the dashboard lights on, the temp. is not moving at all.)
Should I check a setting, is there a switch somewhere (besides from leaving the climate system on "auto", and having enough diesel)? Which fuse can I check? Or, should I talk to the stealer?
Post #204940 Sat Jan 10 2009 11:12pm
Bobby
Killerbob wrote:
..But, the existing solution, this FBH, when does it turn on?
I understand it turns on at a predetermined temperature (some say 5 degrees), IF there is enough diesel in the tank, AND the interior climate system is set for automatic, even if/when the engine is turned off. Also, how do you know it has been turned, or is turned on? KB
Why not spend some time this Sunday to read all you wanted to know about the FFBH fitted to your vehicle...?
http://www.rrsport.co.uk/gallery/albums/us...eater1.pdf
This is on the older models but I think they'll be the same in your vehicle.
I hope this is useful. Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #204941 Sat Jan 10 2009 11:30pm
Killerbob
OK, so having read the document, it surprises me that it seems the FBH is only on turned on during engine operation, or perhaps I am misunderstanding something (English is not my native language).
What is the point then? It should be switching on especially when the engine is not running (to facilitate engine starts), that would make sense!
So, if I undrstand it correctly, how do we make this turn on withour the engine?
Post #204947 Sun Jan 11 2009 12:22am
Bobby
You will get more info here..
http://www.disco3.co.uk/forum/topic15454.html
http://www.rrsport.co.uk/forum/topic12653.html
http://www.rrsport.co.uk/forum/post149447.html#149447 Malaysia Boleh!
Post #204952 Sun Jan 11 2009 1:40am
Shocked incredible Bobby !
btw Kam your car seems to be on fire Wink
Post #204960 Sun Jan 11 2009 8:56am
kam100
Ha... why do you think i sold it? Wink Was a bit upsetting everytime i came out and it looked like it had a smoking issue!
Post #205002 Sun Jan 11 2009 8:29pm
Using the Webasto gsm unit I'm sure it would be possible to get a small in car cigerette lighter powered heater to work. The FBH connected to the timer is a great thing and although as stated it doesn't heat up the interior until the car is started the heat is instant so not really an issue. I seem to remember that the FBH will not work if you have the auto climate control working in the car. 2005 Zambezi TDV6 - Gone but not forgotten
Post #205010 Sun Jan 11 2009 9:36pm
