![]() | Home > Technical > In the rear wheel arch ...electric thingy |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
In both rear wheel arches is what looks like a threaded plastic bolt about 3mm long inserted from behind the wheel arch plastic liner. It has no "nut" on it. If it pops out, it dangles near the exhaust and appears to be some sort of grey coloured electric connector.
mr boombastic Member Since: 08 Dec 2007 Location: NSW Posts: 40 ![]() ![]() |
Yes i have been wondering what they where for too. I knocked one out by accident when i was washing inside the wheel well once. It just seems to be sitting there protruding through a hole and not secured very well. I don't have the TPS system. What is it all about? I |
Hi Bobby
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Can you post a pic to aid diagnosis?? |
Looked around the arch (poor lighting, agreed) but could not find anything like described above. |
You may right there Bobby since they seem to be "terminated". I will try to post a pic but I don't want to have to disassemble the thing again having just put it all back together.
Tyre (or the incorrectly spelled tire |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
Tyre pressure monitoring system (I think) RRS TDv8 HSE Rimini Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
Both |
