| RRSPORT.CO.UK | ||
|  | Home > Technical > Wabasto no start some times |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      |
 Has anyone had problems with the FBH not starting correctly some times and
|  Fri Jan 02 2009 12:11pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | Low battery problems are a major cause !!!
|  Fri Jan 02 2009 5:21pm |
 Thanks wiggs, i can iliminate the battery and the Restraint System , ill have to dig about a bit more, the heater does fire up as i can here it and then cuts out just af the fan kickis into high speed,it also fails the test on IDS   Its not low on diesel , or the low light is not on at least but may be it dont like it when below half a tank for some reason, ill fit it up and try again. Regards Pete Follow Us On Twitter @bellautos | ||
|  Fri Jan 02 2009 5:29pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | Doesen't like inclines either ....
|  Fri Jan 02 2009 7:30pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Thanks, I've just unpluged it to let it power down and I'll try and start it again in about 30 mins.
|  Fri Jan 02 2009 7:51pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | Are you letting it go through its full starting sequence.
|  Fri Jan 02 2009 8:00pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Yes. It does the ticking then fires and sounds ok
|  Fri Jan 02 2009 8:10pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Just thinking about it, I was going to go out the other day, I fired up the heater from the gsm timer all was ok I think.
|  Fri Jan 02 2009 8:17pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | Could well have ...if it had not gone through its sequence and you stopped it ..it shuts down for a while to stop any serious faults .
|  Fri Jan 02 2009 8:51pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | I think I've sussed it , I fired it up water for the fan to go to high speed just where it would normaly extinguish it's self and gave it some propane in the inlet pipe.
|  Fri Jan 02 2009 8:55pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | This may help
|  Fri Jan 02 2009 8:57pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Thanks wiggs ,I think that must be it "flame out" and it cuts the fuel instead of trying to increase it for a second to try and recover the flameout.
|  Fri Jan 02 2009 9:05pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | If you have still got the old FBH ..it may be worth seeing if you can take it apart and check the build up of carbon deposits on the glow pin and flame sensor.
|  Fri Jan 02 2009 9:23pm |
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496      | Good  idea ,Ill do it tomorrow and post some pictures  | ||
|  Fri Jan 02 2009 9:50pm |
| wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99    | Lets hope it stays working   | ||
|  Fri Jan 02 2009 10:11pm |
| Posting Rules
