Home > Maintenance & Modifications > What parts needed to fit Brembos
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Keep with it, its really easy. You'll need to get the brake dustshields (AKA backplates), from LR, just specify they are for a supercharged. Likewise get the discs from LR as they aren't too expensive, also just specify RRS Supercharged and you'll get the correct ones. The existing brake wear cables will switch across so that should be all the parts you need.
If you can post a link to the auction I can give you an opinion on the calipers if you like... Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #187588 Wed Sep 10 2008 3:32pm
R33
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
I tried to fit the Brembo’s I bought at the weekend and I have a problem! I bought callipers off eBay and disc’s/dust shields from Landrover.
The callipers looked OK but when I removed the old calliper the new Brembo doesn’t come close to mounting onto the old calliper mounts. Not only this but even if it did fit the bolt size was smaller on the calliper than the mounts on the car.
Do you need a caliper adapter bracket to mount the Brembo’s onto a 2006 RRS or have I bought the wrong callipers? Big Cry Big Cry Big Cry
I can post some pics of the callipers later.
Post #200087 Tue Dec 16 2008 5:13pm
simonsi
No, the correct Brembos fit directly in place of the std caliper brackets using the same bolt holes and bolts. If your Brembos won't bolt up then you have the wrong calipers Big Cry Cheers
Simon
Post #200104 Tue Dec 16 2008 6:40pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Do the standard NON brembo hoses fit ok on the new brembo calpers ?
I think ive found a source for a few sets of new brembos with pads and discs at a good price Smile
Regards Pete
Post #200147 Tue Dec 16 2008 11:03pm
simonsi
Use your existing hoses and wear sensor, you'll need the Brembo backplates too. Cheers
Simon
Post #200195 Wed Dec 17 2008 10:14am
bellautos
Thanks m8,
i may have a go at cutting the back plates, i fitted some on a FFRR a while agao and he didnt get the plates so i manages to trim his old onesto fit the bigger calipers,
Unless of course the RRS are totaly different shape.
Regards and thanks Pete
Post #200196 Wed Dec 17 2008 10:28am
simonsi
Diameter is wrong too IIRC, not just the caliper cutout. The plates are not too expensive and easily available from dealers... Cheers
Simon
Post #200212 Wed Dec 17 2008 10:55am
bellautos
Ahh i see, do you have to split the baring to get the back plate over the hub ?
Pete
Post #200216 Wed Dec 17 2008 10:58am
