Home > Technical > Dynamic Stability Control cutting in on long left turns
pers1
Norway
My RR Sport car is fitted with DYNAMIC RESPONSE, I have just change the front ball joints after having problems with front suspension knocking noise !
In long left turns the DSC keeps cutting in on my front right wheel, first I thought I had punctured but that was not the case.
I drive the same rout to work everyday and have had no problems before, the speed is about 70- 80 km/h.
The problem started when the knocking noise started more on the right front side than the left.
They have now change some ball joints in the front suspension and said thay had test driven it with no DSC cutting in, "So problem fixed"!
I took it for a long 30 mile test drive and the problem was still there the DSC kept cutting in on the right front tier and the warning DCS light went on in long Right turns
Has anybody here had a similar problem or some advise.
PerS
Norway
Big Cry RR SPORT TDv6 HSE 2007
Buckingham Blue
Ebony Interior
American Straight Grained Walnut
Dynamic Pack HSE
Rear Diff.
20 inch Stormer alloys
Privacy Glass
Premium ICE Pack
Hybrid TV
Personal Telephone Integration system
Tow Pack
Brembo Front Brakes
Bi Xenon Adaptive Head Lights
ADDED on delivery
Grille – perforated with "Titan" finish in buckingham bllue
Twin oval tailpipe finishers
Stormer side vents with "Crome finish"
Post #183006 Thu Aug 14 2008 8:24am
Hoye
Norway 2007 Range Rover Sport TDV6 HSE Java Black
Re: Dynamic Stability Control cutting in on long left turns
PerS
Norway
Big Cry
Maybe this is a special norwegian failure!
I have exact the same with my RRS. The car have been in and out of the workshop for months without any success. However, last week I got the car back again and they had done a lot of minor stuff such as replacing a filter, adjusted steering etc etc. It looks like the car is ok now, but it is more difficult to check it due to the winter road conditions we have now.
If you still have this problem, I would recommend you to call JM-Auto in Arendal and ask Espen for help. He can give you the details of what he have done with my car. Thumbs Up
Post #199617 Sun Dec 14 2008 8:57am
Hoye
PerS
Norway
Big Cry
15th December 2008:
Sorry to say, but I had to inform the workshop again today that the problem still exist on my car. The workshop have been in contact with RR hotline several times but I am not sure if they will mange to repair this failure. Anyone out there with the same problem that have found a solution to it?
Post #199849 Mon Dec 15 2008 5:40pm
Bobby
pers1 wrote:
In long left turns the DSC keeps cutting in on my front right wheel...PerS Norway Big Cry
just out of curiosity.. how did you figure the above? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #199923 Tue Dec 16 2008 12:10am
mr_moped
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
i had this problem on a BMW 330Ci a couple of years ago. Every time I went round a long sweeping bend the DSC would cut in and start breaking my front wheel. After several trips to the dealer and spending alot of hours trying to figure it out, it was finally sorted. The answer was a faulty YAW sensor under the drivers seat. For those of you who don't know what a YAW sensor is, it's the same device they fit on helicopters to stablise the giroscope effect. This is fitted to cars in the event of the car spinning out of control. Thought it might help! Good luck.
Post #200054 Tue Dec 16 2008 3:27pm
ViewWise
Mine cuts on on most bends. Must remember im driving a RANGE ROVER sport and not just a regular sports car Laughing .
Anyone managed to do this? I havent had the balls to try Embarassed .
http://uk.youtube.com/watch?v=-YXQWUBtk_A
http://uk.youtube.com/watch?v=vFR1beBkKrQ
On a serious note ive heard of the bmw yaw thing. Uncles bmw had the same issue a few years back. Took alot of convincing the dealer at the time though from what i remember.
Post #200171 Wed Dec 17 2008 4:39am
BigMart
Yes we will have yaw sensors ( acellerometers) , I dont know where they are fitted.
The other main inputs for the dsc are steering angle ( on the rack) and individual wheel speed.
If you have a worn tyre on side (i'm not saying you have) or the steering sensor set wrong then the dsc system thinks you are very out of shape .
Your dealer should have checked already but I'm sure there is a test they can do for individual wheel speed while drivig in a straight line.
I've known a couple of cars with reduced power and its been the steering angle sensor set wrong(the ecu wont give you full power if it thinks you wheel is turned hard)
Keep us informed.
Mart Jaguar XF 3.0D Portfolio
RRS TDV6 HSE 2006 , Zermatt , Gone
Post #200175 Wed Dec 17 2008 7:32am
Bow down Bow down on the first video Shocked Cool
Post #200182 Wed Dec 17 2008 8:28am
Hoye
Keep us informed.
Mart
Have just been told by my dealer that they will replace the ACE Block which is a module controlling the DSC system. I will let you know the result as soon as the worhave been carried out. Thumbs Up
Post #200224 Wed Dec 17 2008 11:49am
BigMart
If the yaw sensors and the dsc ecu are in the block then great....
If not then you might as well put 2 coats of wax on the car , it wont help.
If somethin is firing the valves in the block , changing the valves wont help.
I hope it works out well.
Fingers crossed
Post #200226 Wed Dec 17 2008 11:56am
Hoye
You feel and hear it as the brakes turn on ! And if you turn off the DSC this want happen.
Post #200410 Wed Dec 17 2008 6:33pm
Isn't this the DSC working? - as you know the system will stop the car by applying it's magic when it feels the car is about to lose itself. 2005 Zambezi TDV6 - Gone but not forgotten
Post #200412 Wed Dec 17 2008 6:37pm
Hoye
In a very nice left turn on ordinary roads with speed not above 60km/h???. Question No this is not normal and the local dealer tested the car with me and they was quite surprised when the experienced this happening.
Post #200413 Wed Dec 17 2008 6:44pm
pelle
Sweden
What was the end of This story?
Post #448713 Sat Jan 17 2015 10:10am
