![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
| Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054
Tsb done. New design ball joints fitted and all is quiet. On a long run Fri so will report back then.
| Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187
Josh fingers crossed |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
Sorry to be the bearer of bad news, but the new revised ball joints WILL NOT cure your problem, it may temporarily fix the issue, but as per the bushes and the whole new air suspension unit - mark my words the noise WILL return.
Dealer told me they've done 4 others so far with no repeat problems so far. So shall keep my fingers crossed, |
...try toes as well 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
| Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555
Just had mine done as well all quiet so far every thing is crossed, but typically on the way home decided to open the sunroof and guess what yes it failed to open so back to the dealer again. |
Well that's two members done. Any more to join us When you getting yours done Will TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Josh, I won't be. As previously posted, the fix is temporary, even though this may seem contradictory to what your dealer is telling you. The ball joints are ONLY replaced if they are outside of tolerance, which mine are not. The ball joints do not contribute towards the knocking noise and are simply a weak spot that LR have uncovered and need to be replaced on certain cars. I would guess that the reason your car has become quiet is because, as part of that process, the bushes are replaced when putting the car back together, hence the subdued knocking. I hope my sources are wrong, but I would suspect that your knocking noise will raise its head once more in the coming few weeks. BTW - Misery had the bushes changed, not the ball joints 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
Got the message Will.
| BIG BAD RANGE Member Since: 24 Nov 2005 Location: KENT Posts: 64
RRSJO hi you write , that you took the 15amp fuse relating to the ARC system and you got a warning light
It will drive but the DR is not going to work.... 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
I only suggested removing the ARC fuse as final confirmation that the knock was being caused by the ARC system and not something else. My dealer has found some cars knock with the violent steering wheel movement test but still knock with the ARC fuse removed. The knock has then been traced to the steering rack moving from side to side. The main thing is to find a dealer who is willing to investigate the cause of any knocking noise, rather than a dealer who just makes assumptions and issues statements along the lines of "thats normal - they all do that". Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293
Knocking solved...
Yup, for sure. I'd go mental if a dealer suggested that the knocking was a characteristic of the car. 2022 P440e AB |
