Home > Technical > Engine Tdv6 to Tdv8
Paparazzi
Engine Tdv6 to Tdv8
Has anyone ever replaced their tdv6 engine with a tdv8 engine. If not does anyone know if it would be a straight forward bolt in and out. What's the cost of a tdv8 engine anyway?
Post #199043 Wed Dec 10 2008 2:31am
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
I don't believe anyone ever has, as you can't even retrofit factory satnav without engineering codes from LR which they will not provide as it constitutes a specification change I can't see a TDV8 transplant being either possible or supported by LR at all.
Best (probably only) route is to sell your TDV6 and buy a TDV8... Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #199057 Wed Dec 10 2008 11:37am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Just be quick, they won't be around for ever Confused L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #199071 Wed Dec 10 2008 1:50pm
Josh
I think it would be highly non cost effective. TDV6 - gone
TDV8 - gone
Post #199094 Wed Dec 10 2008 4:24pm
Paparazzi
The cost of landing a new tdv8 in trinidad is over 100,000 GBP with taxes. I just thought it might be easier to get the engine and swap. there seems to be a lot of commonality between the two engine's systems.
Post #199373 Fri Dec 12 2008 3:11am
Josh
Shocked TDV6 - gone
TDV8 - gone
Post #199395 Fri Dec 12 2008 10:24am
+1 Shocked
Post #199402 Fri Dec 12 2008 10:52am
Paparazzi
Now you see why I suggested the idea in the first place
Post #199431 Fri Dec 12 2008 1:23pm
simonsi
Yes largely the TDV8 is 2 extra cylinders of the same size added to the TDV6 but there are also myriad differences such as EGR valve size etc etc.
The one key difference is that it would require a TDV8 engine ECU which would have to be coded to work with the other ECUs on the vehicle and that is what LR will not provide so she wouldn't run.
Loony price but assume the TDV6 was equally loony or does the TDV8 engine cross some taxation threshold???
It would be more cost effective to have a remap of the TDV6, this can be done remotely via some suppliers offerings....do a search on here and the disco3.co.uk forum for suppliers, it may get you some more oomph at a much better cost Thumbs Up Cheers
Simon
Post #199433 Fri Dec 12 2008 1:30pm
