Home > Technical > Heated rear window
cleeto27
England 2005 Range Rover Sport TDV6 HSE Giverney Green
Heated rear window
Anybody experienced problems with the heated rear windsreen not working?
I have checked the basics ie: the switch lights up & the fuse is fine! RRS TDV6 HSE Giverney/Ivory.
Range Rover Vogue
Range Rover Evogue
Post #198777 Sun Dec 07 2008 10:18am
BKHK
Never use one here near the beach, in fact, you raise an interesting point, I realise that I don't even know where the switch is. I will have a look tomorrow. Laughing Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #198787 Sun Dec 07 2008 1:48pm
PauloAmore
Scotland
Some of the elements in mine failed.
- Replaced under warranty. 2022 P440e AB
Post #198788 Sun Dec 07 2008 3:07pm
cleeto27
warrenty........is that the thing that run's out after 3 years Embarassed Embarassed RRS TDV6 HSE Giverney/Ivory.
Range Rover Vogue
Range Rover Evogue
Post #198789 Sun Dec 07 2008 3:20pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
My rear screen is not working foe some reason, ive also looked at the obvious and it still does not work, im now going to test the screen elements as and when time lets me.
I did have a fault code for rear screen open circuit or output circuit not working on my diagnostic systems but ive not looked deeper yet.
Regards Pete
Post #198909 Mon Dec 08 2008 10:46pm
cleeto27
Pete....can you keep me informed of progress? RRS TDV6 HSE Giverney/Ivory.
Range Rover Vogue
Range Rover Evogue
Post #199029 Tue Dec 09 2008 11:11pm
bellautos
Yes no problem.
Post #199030 Tue Dec 09 2008 11:13pm
lilweliwell
Ireland 2005 Range Rover Sport TDV6 HSE Alaska White
Re: Heated rear window
Hi Cleeto27, I know this post is bit older...but did you figure out what was the issue? I am facing to same problem. Switch and fuse - fine. Even the heating lines are ok - no breaks or damage.
Thanks
Post #282179 Tue Dec 07 2010 12:54am
cleeto27
Sorry never did solve the problem! RRS TDV6 HSE Giverney/Ivory.
Range Rover Vogue
Range Rover Evogue
Post #282197 Tue Dec 07 2010 9:29am
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Did you guys check the connection under the rear spoiler....
Mine had rotted out and had to replace it.....
Alex
Post #282207 Tue Dec 07 2010 10:30am
lilweliwell
I did change the fuse...still not working...I think last time saw it working 3 - 4 week ago...it wasn't so cold...since last week temp.dropped to -2 to -9. I checked the lines again - no damaged...i would check the wiring under rear spoiler but don't know how
Post #282289 Wed Dec 08 2010 12:25am
