Home > Technical > Multiple warnings?
jimmyboy
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Multiple warnings?
Hi All,
I would appreciate your thoughts on the following:-
I purchased a brand new RRS TDV6 HSE a few weeks ago, now done approx 750 miles. I recently had a warning come up on the centre dash, "Transmission fault", along with HDC Fault, Park Break Fault, "tilt over warning" and the message "Lowering suspension". I would be driving along, without any particular strain on the car.
This has happened twice now, and is cured by switching the car off, then on again. The car drives without any symptoms, so my head tells me this must be an electrical/computer glitch. LR Assist tell me this is "dealer refferal", so I have booked in with my dealer to have this looked at. lets see what they come up with.
My question is, have any of you had simmilar troubles, and if so, what has been the cause?
Thanks for any info.
James. 09MY RRS TDV6 HSE
Post #198012 Mon Dec 01 2008 11:18am
This is a common problem especially on new cars. Your dealer will plug a diagnostic computer into the RRS to see what the problem is. If the fault occurs again it is best to get Land Rover Assist out straight away and get the car to a LR service centre. DO NOT LOCK THE CAR as this will reset the system and make finding the fault more difficult. 2005 Zambezi TDV6 - Gone but not forgotten
Post #198013 Mon Dec 01 2008 11:21am
jimmyboy
Thanks VA. Sadly, I have locked the car, so in a perverse sort of way, I hope the fault happens again now!!
You say common problem on new cars...so is it always the same cause, i,e a common wiring/short/sensor fault??
Post #198014 Mon Dec 01 2008 11:26am
It can be a number of things all of which are usually minor. More often than not it's a faulty sensor. 2005 Zambezi TDV6 - Gone but not forgotten
Post #198016 Mon Dec 01 2008 11:39am
BKHK
My car came up with 'Transmission Fault" with barely 140km on the clock as I was driving it into the driveway after picking it up new from the stealer. Oh sh.t I thought. I have never had any warnings of any description since...maybe it was just getting used to being driven? It has been great ever since. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #198019 Mon Dec 01 2008 12:09pm
jimmyboy
Thanks all, lets hope its an easy fix!!
Anyone else with simmilar problems past or present?
Post #198023 Mon Dec 01 2008 12:52pm
I had it from new 3 years ago! Fixed itself after a while. 2005 Zambezi TDV6 - Gone but not forgotten
Post #198024 Mon Dec 01 2008 12:54pm
jimmyboy
Not sure if it is related, although I suspect it may be after reading a few of the posts on this site......I have noticed the car does not get quite as warm as I suspect it should do in the mornings. It was very cold this morning (0deg C) but after 6 miles, the car was chucking out warmish air, but nothing that hot, even with the temp dial right on its hottest settings. It was the GF that noticed this, but I suspect she may be correct, as it gets no-where near as hot (air heater-wise) as my BMW did.
Also, the temp guage this morning didnt quite reach where it normally sits after a few miles.
anyone else experienced the same? "how hot does your TDV6 get" (not meant to sound funny!)
I see there is a TSB about a Thermostate and EGR low flow problem causing these warnings to flash up (TSB LTB00124), so perhaps there is something in it not quite getting hot enough this morning????
Post #198027 Mon Dec 01 2008 1:05pm
that's what you get when you put a french engine in an english car Wink joke aside its a modern Diesel engine and they don't get warm enough during winter time.....
Post #198031 Mon Dec 01 2008 2:04pm
Leo
Kenya
don't you have the fuel-blown heater? Confused
Post #198036 Mon Dec 01 2008 2:47pm
jimmyboy
Fuel blown?
Im not sure what that is? 09MY RRS TDV6 HSE
Post #198037 Mon Dec 01 2008 3:11pm
sure i do - but the engine still isn't getting warm enough... Rolling Eyes
Post #198038 Mon Dec 01 2008 3:18pm
Bobby
FFBH - fuel-fired booster heater! Laughing Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #198099 Mon Dec 01 2008 11:00pm
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Sounds like your Fuel Burning Heater may not have fired up, anything below 4deg should result in the FBH (front of engine bay on left side) firing up to assist the engine coolant to warm up properly and provide decent heater output. In traffic at such low temps it may kick in again to maintain the coolant temp.
When running you should hear it and probably see the exhaust under the front left side of the engine bay.
Careful if you feel for the exhaust as it is HOT when running. Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #198100 Mon Dec 01 2008 11:08pm
Frosty_Power
Canada 2006 Range Rover Sport 4.4 V8 HSE Alaska White
I've had this warning come up twice since I purchased a used RRS a couple months ago. It only happened when it was really cold outside and we parked the vehicle outside and not in the garage. Never happened when the weather was warm. My RRS must not like the cold weather Big Cry .
Post #198108 Tue Dec 02 2008 12:33am
