Home > Maintenance & Modifications > Transmission Fault Warning
blueturret
2006 Range Rover Sport TDV6 HSE Java Black
Hi
Since yesterday on three ocassions my V6TD has told me that it has a Transmission Fault. However it still appears to be driving fine and if I stop, turn the engine off, remove the keys then restart, the system check appears to give it a clean bill of health.
I am going to take it to my local deal, since its just over 2 years old and still under warrant, but was wondering whether anyone had had a similar message and the likely problem (s).l
thanks
Post #197963 Sun Nov 30 2008 3:09pm
Fairly common problem and a soft reset will often sort the problem out. If the problem persists it is a visit to your dealer will be needed as cause can be a number of things. Not something to worry about. 2005 Zambezi TDV6 - Gone but not forgotten
Post #197964 Sun Nov 30 2008 3:58pm
blueturret
Cheers - this may seem like a daft question, but what is a soft reset?
Post #197966 Sun Nov 30 2008 4:48pm
Basically what you did. Using the key fob lock the car, unlock it, lock it, unlock it = soft reset. 2005 Zambezi TDV6 - Gone but not forgotten
Post #197967 Sun Nov 30 2008 5:01pm
blueturret
thanks, will try that and hopefully it will sort itself!
Post #197968 Sun Nov 30 2008 5:13pm
