![]() | Home > Technical > Looks like my clutch is dying! |
| BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324
you have PM
| bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496
Does this box have a filter, i cant seem to locate it on Microcat.
Hello Pete,
Thanks for that mart, ive found the sump/filter on microcat, itlooks as tho it can come as a kit with the gasket and seals etc etc. This will make life easer.
| Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497
Having no technical knowledge, but an enquiring mind; VA's car has done far less miles and far less off road (both in amount and difficulty) than many D3s; so why would that be a factor? We haven't seen any thing like this on the D3 site, despite older cars, although I suppose some are manuals. Porsche Cayenne S Diesel 66 Plate |
Driver abuse ?? |
Thanks for all the advice everyone.
| Nutty Nige Member Since: 21 Feb 2007 Location: Staffordshire Posts: 355
If it is clicking as well VA it might be the prop shaft spline spinning on the final drive unit. It is very common on Freelander and RR Vogue. Sounds more like that than the transmission. You don't stop playing because you get old, You get old because you stop playing.
| highbridgeflyer Member Since: 06 Aug 2006 Location: Midlands Posts: 113
Given that LR have done a nation wide diff upgrade on the FFRR (from spline to flange) I would agree |
| PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355
Are you sure that the transmission and drive train aren't still covered under warranty (not the standard 4/50 or equivalent in the UK, but the normally longer drive train warranty), and at any rate, the recommended change of filter and oil for the transmission is every 100k miles on the RRS, and the gearbox fluid is EXPENSIVE, so doing it every 20k is going to set you back a fair amount.
They did 2 mods Mart - a tool to line up the diff with porpshaft on front as the angle was seen to be wrong between the two, and then a build mod - but after the mod I had 2 fail with the same problem. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
What would you prefer is the obvious question - a transmission service every 2 years at £80 or a replacement transmission 6 months after warranty expires at a guess I would think around £4000 - £7000 It depends on application if you potter round all day chances are it will be fine. If you get it stuck in the mud or tow a heavy obstacle behind when do you think - I will now stop for an hour to let the transmission fluid cool down due to the excessive pressure and heat I have just bestowed upom my car?? Your choice. You don't stop playing because you get old, You get old because you stop playing. 07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old. RS Cosworth 4x4 Stage 2 Mint for summer Audi TT Astra VXR for the daughter. |
4 Ltrs of LRs Advanced ATF designed for the D3 and RRS autobox, £18.54+vat per ltr retail.
Thats interesting Pete,
| All times are GMT |
