![]() | Home > Maintenance & Modifications > better response and no smoke.....it is possible....read on |
gazza500 Member Since: 01 Aug 2007 Location: Channel islands Posts: 176 ![]() ![]() ![]() |
I can confirm that putting some T2 in the fuel does have some amazing effects on the general performance of the engine.
Korenai Member Since: 05 Oct 2008 Location: Lugano Posts: 244 ![]() ![]() ![]() |
Ok, I'll go for it as well... I found some semi-synthetic JASO FC 2-stroke oil at 4.4 £/L. |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
You will see instant results , the next time you do a cold start , |
Full tank of Shell V-Power diesel, 400 ml of oil and 350 kms later... A little bit quiter (maybe) and less smoke... For now, it is all. |
jjb218 Member Since: 22 Jul 2006 Location: Dominican Republic Posts: 94 ![]() ![]() |
Hello, I read the post and I was on my way to the Marina and discovered that the only 2 stroke oil was for marine outboard engines, one was mineral (didnt say anythign about synthetic) and the other one said " synthetic mix(es).
Hi JJB,
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589 ![]() ![]() ![]() |
An update:
My update,
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 ![]() ![]() ![]() |
It's funny to see how we keep re-inventing things:
I'm in Switzerland as well, I'm using the FC semi-synth 2-stroke oil from Coop, found in the do-it section, 7.90 CHF/L, it does the job well! |
