Home > Technical > Cannot get in to trip computer
gazza500
Jersey 2008 Range Rover Sport TDV6 HSE Chawton White
No matter how I try I cannot get in to the on screen trip computer using the left hand stalk. Is this a known issue? How did you get around it?
Thanks for the help in advance Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Privacy Glass, 22 inch, Hawke Alloy Wheels, Brembo Front Brakes, Premium ICE Pack, Clear repeaters, Chrome Driving Light Surrounds, Tasmods, Chrome handles, HST Grille, Chrome Side Vents, JE ECU Upgrade
Post #194346 Mon Nov 03 2008 9:53am
Does the "i" button not work at all?
Post #194348 Mon Nov 03 2008 9:58am
gazza500
Hi Shmoogle,
No, no matter how hard I push Whistle or what procedures I use, switch off ignition, lock, relock etc. nothing happens Big Cry Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Post #194349 Mon Nov 03 2008 10:01am
Hmm... well, clearly that's not right. Has it ever worked? If it has and now it doesn't... then I guess there's an electrical contact issue. Time to drop by the dealer I suppose Very Happy
Post #194350 Mon Nov 03 2008 10:03am
gazza500
Thanks mate Thumbs Up Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Post #194356 Mon Nov 03 2008 10:15am
I think you can only access the changeable functions whilst stationary.
You should be able to change between fuel consumption etc whilst on the move Thumbs Up Runner up - 2009 Best Avatar Award Sad
Post #194388 Mon Nov 03 2008 11:48am
MAW
Correct - settings access only whilst static - MPG, range etc at all times
let us know the outcome
Post #194407 Mon Nov 03 2008 12:28pm
Korenai
Switzerland 2007 Range Rover Sport TDV6 HSE Java Black
If it still not working, go for a soft reset.
Post #194458 Mon Nov 03 2008 2:38pm
gazza500
It sudddenly came back again, no rhyme no reason Rolling Eyes Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
Post #194759 Tue Nov 04 2008 7:39pm
Korenai
At some point, my trip was stuck in settings... Couldn't go back or change anything. Turn it off, waited a couple minutes, everything was fine. No need to worry I guess.
Post #194822 Wed Nov 05 2008 10:51am
